Looks awesome!
Do you think the 295/55R20 you have would fit on a 2" level?
Are you experiencing any rubbing at full lock in reverse with how you have it setup currently?
I'm sure you could. You might have some slight rub like I do, but its not enough to cause any issues. I only rub if I'm fully locked going forward and go over a bump, or fully locked in reverse.
Zone C1200 2" level kit and BDS 1" rear block installed yesterday. I'm liking it, just wish I could fill that wheel well a little more.
Don't worry about filling the wheel well it looks great! :chevy::flag:
I've got -12 so maybe the fact that your wheels stick out a little more helps. I may be wrong, but I also thing the 2016 truck have some more clearance or something up front because another member on here BruceBruce was running 20x12's with 33's and claims no rubbing at all. Whats done is done tho. I'm still happy with my decision.
That could be the case, but either way your truck looks good!
Thank you sir! As does yours!
Dad's '14 Denali, Brother's '14 Silverado, my 2 yr old son and I are rocking the 14' Sierra's! We have been a GM family for many years and many trucks.
  • Like 6
Love the 2 yr old's Denali, that's a sweet ride!!
Oh of course all the others are nice too! [emoji12]
Sent From My Galaxy S6 Edge+
He loves it. Goes straight for the dirt with it and it even has an MP3 player!
Man I want one! Have you taught him to detail and wax it after hitting the dirt yet??
NIce truck Bud... Finally someone who has the same wheels as me... Wheels look sharp with that Color Truck..
I'm looking into buying these wheels for my 15 and almost no one has these wheels. I'm surprised because they are really nice. Nice truck
Nice looking Truck!!! Where did you get the black Sierra door emblems? I have looked online and ordered some off Ebay but they are not aligned properly to "just stick on the door". Looking for Black Denali door emblems as well. Thanks!
Thank you, I just plasti dipped them. I haven't had the courage to remove them and get them painted because I'm worried about lining them up again.
C'mon guys. These pic post are useless without specs. :dunno:
With 369 pages of posts, it's almost impossible to keep up with the different setups.
It would be great if everybody included:
Year
Lift/Level size
Tire size and mfg. Road noise!
Rim size with offset
Trimming
Rubbing
:rant:
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
