2016 Chevy Silverado Z71 4X4
20x9 FUEL Hostage +1
BFGoodrich KO2 275/60/R20
Amp Research PowerStep
Range AFM Disable Device
Flowmaster Exhaust System
Readylift 2-1/4" Rear Blocks,
2.5" Front Level
AFE Power Filter
Blacked Bowtie Badges
vvXGAXt.jpg?1
xEs9ZYf.jpg?1
nY9l59R.jpg?1
  • Like 7
Emblem off:
PPF on: [emoji2]
Sent From My Galaxy S6 Edge+
Looks a lot better with the emblem off the tailgate.
Installed the leveling kit this week
Which kit did you go with? That stance looks perfect!
Sent from my Nexus 6P using Tapatalk
Suspension maxx. They included the brackets for the magneride.
2016 Chevy Silverado Z71[/size] 4X4[/size]20x9 FUEL Hostage +1[/size]BFGoodrich KO2 275/60/R20[/size]Amp Research PowerStep[/size]Range AFM Disable Device [/size]Flowmaster Exhaust System[/size]Readylift 2-1/4" Rear Blocks,[/size]2.5" Front Level [/size]AFE Power Filter[/size]Blacked Bowtie Badges[/size]
vvXGAXt.jpg?1
xEs9ZYf.jpg?1
nY9l59R.jpg?1
Badass unit bud! Love the red.
looks good. bowtie - red / black also black letters ??
I am blacking out the badges when I get a chance (plasti-dip job didn't turn out right) ... and the Bowtie has already been blacked out in the front and back.
The small amount of chrome is okay ... it kinda offsets all the red and black a bit overall.
OK, so I've been on this site for about a year now.. Just been creeping around the forums.. Now since I have a decent amount of stuff done to my 2015 Sierra Denali. I'd like to share some photos and some info..
Black vinyl roof and B pillar..
7" rough country lift for magneride.
Rough country traction bar.
22x12 et -44 Xd Grenade
325/50r22 Cooper STT Pro
Rollbak tonneau cover.
Pop n lock tailgate actuator.
Opt7 5k headlights
Opt7 3.4k fogs
I'm sure she's not finished yet..
  • Like 7
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,087 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
