Pro Comp 1.5" level
RTX Ridgelines w/Enkei center caps, 20x9, +15
Toyo AT3 275/60-20
Corsa Black (Actually black chrome)
Bak Revolver X2
I'm also running a 1.5in level and was wanting to run 275/60/20s but wasn't positive it would fit without rubbing. I've got a couple of questions if you don't mind. Do you have a pics down the side of the truck from front and back?? Also what is your front wheel well height through the center of the wheel?? I'm assuming no rubbing, but how close are you to rubbing with the +15 offset, I was looking at either +12 or +00 offset and would like to get an idea at what I may run into trouble wise. Thanks.
Pro Comp 1.5" level
Toyo AT3 275/60-20
Bak Revolver X2
Beautiful truck, just picked up mine in summit white.
I'd suggest color matching the body side mouldings, plasti dip or something similar that will protect the chrome and be reversible if you don't like it. Your truck screams for window tint imo. Hard to look away from that red and black combo !
I talked a buddy of mine into a new GM truck. Be ended up picking this one out. A new 2016 Silverado 4x4 5.3l v8
looks good - maybe a black bowtie ?
My new truck. I plan on putting a Rc level on it for now until the bilstein 6112 shocks are available. I plan on changing the bow tie to black as well.
Edited by jsapp2013
  • Like 3
20X9 WORX beast (bought used wheels and tires)
Rough Country 2" front leveling kit
Removed GMC emblem from rear
Deleted muffler and resignator, ran duels tucked at the hitch
Coming from a '14 Sierra AT, to a '16 LT Z71 - many mods to come very soon :devil:
looks good - black bowtie / black letters ?
Edited by tahoe08
Here's my 2015 5.3. I originally had a 2.5" leveling kit but decided to install Fox shocks on all corners, Cognito upper control arms, and a 2" block in the rear. I think I'm done for a while!
Looks good!
ahah it too funny because I was on ebay todday looking at my options and also requested a photoshop pic to see what black emblems and lettering would look like,
Current plan is: 4" BDS kit, black Mayhem Warriors, 34.5x12 KO2s (install next week, ordered), window tint, remove side letters, black/red lettering on the tail and black bowties.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 715 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
