Updated 2014 truck constraints
Constraint is putting it lightly. Discontinued is more like it. You're gonna be waiting a while for that one.
The rear sliding window-discontinued? Source? I'm either about to put down a deposit on '14 build (waiting for dealer to come back with price) or since I keep hearing about restraints on other things I want (6.2, Max tow), I may just wait until '15 models come out and hopefully clean up first year bugs. A sliding rear is mandatory for me - enough so that if it is wholely discontinued I could get a Silverado/Sierra (will have truck cap w/ dogs in back).
As of week of Mar 3 sliding window should again be available to order with the SLT (4SA)
Week of 3/3/2014
Effective 3/3/2014, the following changes will be made to the Vehicle Order Guide:
  • Crew Cab and Double Cab Interior section-Added (A48) Window, power, rear sliding with rear defogger, with "A" availability on 4SA.
  • Crew Cab and Double Cab Mechanical section-(NHT) Max Trailering Package, Updated footnote 1 to read "No longer available on 3SA as of March 6, 2014. Includes (G80) heavy-duty automatic locking rear differential on 2WD models (already standard on 4WD models) and Z82 Trailering Package. Requires (L83) 5.3L EcoTec3 V8 engine. Not available with (Z71) Off-Road Suspension Package. Includes (UHN) 18" X 8.5" bright-machined aluminum wheels with (RBX/RBW) 18" tires or may upgrade to (RD3) 20" aluminum wheels with either (RC7) or (QSS) 20" tires.". Updated footnote 2 to read "No longer available for the Model Year with (L83) 5.3L engine, requires (RBX/RBW) 18" tires or may upgrade to (NZM) 20" chrome wheels or (RD3) 20" ultra bright machined aluminum wheels with either (RC7) or (QSS) 20" tires. With (L86) 6.2L engine, requires (NZM) 20" chrome wheels or (RD3) 20" ultra bright machined aluminum wheels with (QSS) 20" tires. Not available with (Z71) Off-Road Suspension Package.".
  • Sierra 1SA and 3SA Color and Trim-Added (G7J) Exterior Color Emerald Green Metallic "WA-136X", "A" available on all interior trims with a new footnote 4 that reads "Requires Crew Cab or Double Cab and 3SA interior trim. Available at extra charge.". Old footnote 4 becomes footnote 5, old footnote 5 becomes footnote 6 and old footnote 6 becomes footnote 7.
  • Sierra 4SA Color and Trim-Added (G7J) Exterior Color Emerald Green Metallic "WA-136X", "A" available on all interior trims with a new footnote 3 that reads "Requires Crew Cab or Double Cab and 4SA interior trim. Available at extra charge.". Old footnote 3 becomes footnote 4 and old footnote 4 becomes footnote 5.
You've GOT to be kidding me? This thing is available again? Well *%#~ me sideways isn't that a crock of sh*%.
I'd order. Hope u get it. Seriously. But don't get too disappointed if GM decides to drop it again. And maybe the 6.2 as well for some unbeknownst reason.
Just ordered my silverado ltz last Tuesday and I couldn't get a spray in bed liner, or the hd floor mats, but got everything else including sliding rear window.
Week of 3/3/2014
Is it possible that the rear window went back on constraint after this 03/03 update?
Some of you are 4-5 months out on sold orders? Glad I ordered 1st thing. Wonder if these Will coast on to the 15' model year?
Will
Note that it's only available on 4SA, (which is SLT).
Don't see any other updates on the rear window option, so they should be able to add it to an SLT.
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
    • Why do they have the gas 10l80 opening at 145?
