alrighty, well have fun buying a $900 tool to fasten your u bolts, ill stick to my general conscious ;)
LOL you know they are only $10-$40 right? A nice digital one runs $100-300, and you can even get a torque wrench that does it all for $300
https://www.google.com/?gws_rd=ssl#q=torque+angle+gauge&tbm=shop
https://www.google.com/?gws_rd=ssl#tbs=vw:l,mr:1,price:1,ppr_min:200&tbm=shop&q=torque+angle+gauge
I only buy quality tools! :)
5C579BF6-2E57-487B-B708-21ABB2DD8433_zps
Anyhow, that's just my opinion. I've tightened literally 100's of ubolts and have had zero issues without angle torquing them. Obviously the extra step doesn't hurt, I just don't think it's necessary.
If I'm working on an engine, then it's a different story.
  • 8 months later...
Does anyone know the correct torque specs for the 2017?
Edited by KurtA
The Cognitos UCA instructions re-use the factory hardware to attach to the frame and specify 90ft lbs. So unless you hear from someone else, I think that's a safe bet.
So I hate to be the guy that beats a dead truck, but these will apply for all the K2XX platform trucks, including the '17 Sierra?
I ask because I called one local dealer, and they were rather reluctant to tell me anything at all about what the service manual contains. So I called another, and they've been unable to find anything in their FSM. So I called the local Tire Discounter and they gave me
Upper Strut Mount Bolts - 89 Ft Lbs
Tie Rod End Nut - 1st Pass 26 Ft Lbs, 2nd Pass 85-100 degrees
Sway Bar Nut - 48 Ft Lbs
Upper Ball Joint - 1st Pass 85 Ft Lbs, 2nd Pass 85-100 degrees
And I felt like 85 ft lbs was just asking to lock up a ball joint...
EDIT: So I talked to a tech at the dealership I purchased from and confirmed that the specs listed on p1 of this post are in fact for all K2XX Light Duty pickups. :-)
So the installation continues...
Edited by nmyron
  • 3 years later...
14 hours ago, king kong said:
I was wondring if maybe you have the factory specs if the truck has the z71 package?
Zero difference.
On 11/1/2020 at 1:01 AM, king kong said:
Factory they were at 80 lb ft not sure how they would be the same.
Zero.  Difference.  2wd, 4wd, with or without Z71.  The same.  They use the same bolts, u-bolts, nuts, etc.
Would the specs be different from a 1500 to a 2500?  You bet.
  • 4 months later...
Guys, I did a FabTech 6" lift on my 2018 1500.  I have a popping in the steering, and I need to check the factory torque settings of the factory bolts that hold the rack and pinion in.  I'll also want to check the steering shaft coupler that connects the column shaft to the R&P.
I can't find their factory torque anywhere.  I would love to get a full guide of all torque specs for the this truck, but if I can't find that, does anyone happen to have the specs for the R&P bolts and shaft coupler?
Also, I read some interesting reply in this thread earlier about Torque, Torque to Angle, and Torque to Yield.  I'm curiously wondering if these bolts are Torque to Yield and require replacement with factory bolts.
Thanks in advance for any help anyone can offer.
RC
Hi Yall,
Wondering if anyone knows what the torque specs are for the front driveshaft connecting to the differential? I need to loosen the driveshaft in order to access the the t-stat so I can install my tbv kit. It's pretty much impossible to access the t-stat housing with the driveshaft where it is. Any help would be appreciated!
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
