alrighty, well have fun buying a $900 tool to fasten your u bolts, ill stick to my general conscious ;)
LOL you know they are only $10-$40 right? A nice digital one runs $100-300, and you can even get a torque wrench that does it all for $300
https://www.google.com/?gws_rd=ssl#q=torque+angle+gauge&tbm=shop
https://www.google.com/?gws_rd=ssl#tbs=vw:l,mr:1,price:1,ppr_min:200&tbm=shop&q=torque+angle+gauge
I only buy quality tools! :)
5C579BF6-2E57-487B-B708-21ABB2DD8433_zps
Anyhow, that's just my opinion. I've tightened literally 100's of ubolts and have had zero issues without angle torquing them. Obviously the extra step doesn't hurt, I just don't think it's necessary.
If I'm working on an engine, then it's a different story.
  • 3 weeks later...
  • 8 months later...
  • 2 months later...
Does anyone know the correct torque specs for the 2017?
Edited by KurtA
The Cognitos UCA instructions re-use the factory hardware to attach to the frame and specify 90ft lbs. So unless you hear from someone else, I think that's a safe bet.
  • 1 month later...
So I hate to be the guy that beats a dead truck, but these will apply for all the K2XX platform trucks, including the '17 Sierra?
I ask because I called one local dealer, and they were rather reluctant to tell me anything at all about what the service manual contains. So I called another, and they've been unable to find anything in their FSM. So I called the local Tire Discounter and they gave me
Upper Strut Mount Bolts - 89 Ft Lbs
Tie Rod End Nut - 1st Pass 26 Ft Lbs, 2nd Pass 85-100 degrees
Sway Bar Nut - 48 Ft Lbs
Upper Ball Joint - 1st Pass 85 Ft Lbs, 2nd Pass 85-100 degrees
And I felt like 85 ft lbs was just asking to lock up a ball joint...
EDIT: So I talked to a tech at the dealership I purchased from and confirmed that the specs listed on p1 of this post are in fact for all K2XX Light Duty pickups. :-)
So the installation continues...
Edited by nmyron
  • 3 years later...
14 hours ago, king kong said:
I was wondring if maybe you have the factory specs if the truck has the z71 package?
Zero difference.
On 11/1/2020 at 1:01 AM, king kong said:
Factory they were at 80 lb ft not sure how they would be the same.
Zero.  Difference.  2wd, 4wd, with or without Z71.  The same.  They use the same bolts, u-bolts, nuts, etc.
Would the specs be different from a 1500 to a 2500?  You bet.
  • 4 months later...
  • 3 weeks later...
Guys, I did a FabTech 6" lift on my 2018 1500.  I have a popping in the steering, and I need to check the factory torque settings of the factory bolts that hold the rack and pinion in.  I'll also want to check the steering shaft coupler that connects the column shaft to the R&P.
I can't find their factory torque anywhere.  I would love to get a full guide of all torque specs for the this truck, but if I can't find that, does anyone happen to have the specs for the R&P bolts and shaft coupler?
Also, I read some interesting reply in this thread earlier about Torque, Torque to Angle, and Torque to Yield.  I'm curiously wondering if these bolts are Torque to Yield and require replacement with factory bolts.
Thanks in advance for any help anyone can offer.
RC
  • 1 year later...
Hi Yall,
Wondering if anyone knows what the torque specs are for the front driveshaft connecting to the differential? I need to loosen the driveshaft in order to access the the t-stat so I can install my tbv kit. It's pretty much impossible to access the t-stat housing with the driveshaft where it is. Any help would be appreciated!
  • 1 year later...
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,056 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
