I do not have that lever on my steering column or the rubber plug to the left of it. Must be for telescopic steering I just tilt?
Correct.
Ordered my 20" Vision X light bar yesterday. It's the Xmitter Low Profile Xtreme 5w Wide http://www.visionxusa.com/LED-LED_Bars-Xmitter_Low_Profile_Xtreme_Light_Bar/c1_288_214/p853/20"_XMITTER_LOW_PROFILE_XTREME_BLACK_15_5W_LED&%2339;S_40degree_WIDE/product_info.html?osCsid=467gkqbh36bh5j169nmk2o6rd3
Hopefully it comes in before the weekend. Will post pics of install when complete.
EDIT: tracking number shows Monday delivery :(
Edited by MotoMedic
^ $600 for that, i'll pass... lol
motomedic is a drug dealer so hes got bills to toss around. :pimp:
The correct term is "illegal commodities broker" thank you! :smoker:
I actually work for an oil company, which is similar because both businesses provide highly desired products at artificially inflated prices! haha
  • Like 8
Are they hiring? I'm willing and able to relocate.
Sent from my iPhone.
Well when you get it, hurry up and get it installed so i can look at it and follow suit lol
I live in Lafayette as well so feel free to PM me if you'd like help.
I plan to mount one in the same space as you. I might even add a 30" behind the grill (for shiggles).
I'm probably going to go with Chinese versions though as i cant bring my self to drop the coin that rigid/visionX etc wants for theirs. I know that they are made in the US (supposedly) but $500+ for a light bar is ridiculous to me (No offense).
Pulled off the bumper tonight, removed the plastic trim piece to expose underlying metal, and test fit my new light bar. Fits perfect and looks pretty sweet IMO. Plan on doing permanent mount/wiring this weekend. Pics of bumper & test fit attached.
  • Like 7
And den?
Messed with the LED fogs tonight, kids soccer game tomorrow, so it's been pushed back to Thurs night... maybe Fri. ha
ARRRRRRGGGGHHH!!!!!!
Got my light bar put in and the bracket I fashioned didn't work as planned! The light bar is angled down about 10-15 degrees from level. Soooooo ticked right now!
I did go ahead and light it up anyway... sucker is bright! Pic below doesn't do justice because light is focused at a spot on the ground about 10 ft in front of the truck. Reflection washes out iphone camera, but even pointing down, you can tell it puts out more light than my HID headlights.
    B07
    B07
  • Who's Online   1 Member, 1 Anonymous, 871 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
