Got my rigid kit and D2s. Will install soon. Just curious about wiring. Would like to connect to stock wiring. Do I need anything to accomplish this or just tap into the stock wires? Thanks
I would think a relay off the battery triggered by stock fog socket/output would be safest bet.
Not sure if I follow? Sorry.
Are you saying I need a relay on the hot wire on the stock harness?
Run a relay to the battery and then instead of hooking it up to a switch to activate it, hook it to the stock fog light plug
Installed the rest of my light bars. I now have one 20" in the center with two 7" ones on either side. Also originally had the 20" mounted on the bottom of the grille but decided to move them all up top. The light output is amazing!
Here is low beams only
Here is low beams with light bars
Sent from my SM-N900T using Tapatalk
Edited by corwest
I cut the factory fog plug wire off and attached the Rigid connector - no relay, not separate hot wire - zero issues thus far.
So you did not use a wire harness?
zero wire harness - took 5 minutes -
How many amps do the lights you install pull?
This is sounding better all the time. My first choice is to install the D2s in a way that I could reinstall the stock fogs in case I change trucks.
I have also heard about a way for these fogs to work with high beams and low beams? Has anyone done this? Thanks
http://www.gm-trucks.com/forums/index.php?/topic/162734-Foglights-On-With-High-Beams
Yes, mine are configured this way and it works great. You can't go back to factory unless you buy the OEM fog light cup due to cutting during installations.
Mounted and wired my 30" light bar. Looks good might just have to aim it up a little also plasti dipped my honeycomb . aa3f8ab376b50a0117730cce3d787866.jpg2de4e731cc82612d29aaa7cab58b23e8.jpgdf11e9f228bc0e3c2eaf984489d7d735.jpg
  • Like 5
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
