Do you drive with your fog lights on? I just installed mine today, and they are BRIGHT!
Just curious..
I drive with everything on when no one is around! Or when someone infront of my is driving like an a$$ haha.
But on a serious note, I don't usually drive with them on. They are too bright for normal use. This weekend I'm hoping to get a few minutes to try and see if I can't cover half the light with something to keep the light from shining upward too much so they could be used on road.
c7b9184e87d074a2a0847519948e491a.jpg2adf70cc7a819f74eb7001f060a6ecd1.jpgfe8d03754662c4906365b8607e8f9d33.jpgd9ede5e418727a082debce524508fd01.jpg
Sorry guys for the late pics. You will notice against the garage regular low beam and then the new D2 Rigids. Also pics of the truck. Just love the lights and how they work! Outstanding to say the least.
I agree 100%! I love mine! So glad I pulled the trigger to do this mod.
Thanks, I was wondering what to do as well. If they are driving lights, I would figure they could be used...
Not with how bright they are. Also I'm surprised at how far up they shine and not out to the sides. Wish I could turn the pods so instead of shining so high and low they would shine side to side.
Looks good.
Where's the best place to run your wiring from the bars and into the cab to mount the switch?
on the main harness feed into the cab beside brake booster the rubber grommet has a small tab cut the end off and your wire will feed in the cab tape your wires first I used blue so I could find it in all the black mass of wires
You have to add a circuit using a relay. The easiest way is to buy a wiring harness kit on Ebay.
http://www.ebay.com/...f399fa5&vxp=mtr
On the relay, you have four wires, one that goes to the battery, one that will do the ground, one for your LED bar and one for the switch and the signal wire.
Personally, I never install switch, because must be drilled for the dashboard. Normally, I use existing channels, such as the original fuse for fog lights or the fuse for the highbeams with a fuse tap. Look at the map below the fuse box inside your hood to find one that will make your case.
The signal is used to tell when your circuit must pass power. So if you use your original fuse for foglights, it means that when your fog lights will be lit, your LED light bar too. You can also choose to turn your LED bar ON when you put your highbeams. If you want absolutely a switch, It's the same circuit.
For the GMC 2014, It's the # 49 for the fog lights and #58 for the highbeams.
so the wire i have to my switch is made up of 3 wires (black, blue, white). To eliminate the switch and plug into my highbeam fuse with a fuse tap, do i join all three wires into that one fuse?
Not the black! The black is your ground and the fuse tap will put off a live power. So hooking all 3 to it will do nothing. The black will need to be grounded
Not the black! The black is your ground and the fuse tap will put off a live power. So hooking all 3 to it will do nothing. The black will need to be grounded.
so i just join the other two and ground the black?
Well what bar is it? I'm surprised it has 3 wires. Does is have a second color? Most bars only have 2 wires. Or at least all the bars I've had over the years have only had 2 wires.
i have the bar wired up to a relay that has wiring for a switch. The wiring to the switch is made of the three wires, i want to eliminate the switch and just tie the wiring into my high beam fuse.
Oh okay. Idk why i thought you meant the bar had 3 wires. My bad.
Just putting the white to power should be sufficient. That is usually the actual activating wire if I'm correct. The blue would be to power the light that is on your switch.
your blk needs to go to the relay white is your power so it will go on 30 and out on 87 back to your lights 85 will feed a signal to relay from your high beam fuse blue is usually a power feed to show on a light switch that the lights are on that one don't do anything with it
thanks guys. got it wired up. Turns out the blue was my signal wire, so i plugged it into my fuse #58. I grounded off the black to the truck and capped off the white.
Thanks, I am going to do it this way. Hope the wires feed through the grommet tab ok and don't get lost in there somewhere on the way into the cab. Mike thanks for your info but I'd rather not do any drilling and messing around splicing in the console
I just installed my duallies in the foglights. Excellent mod and light output is great. I spliced directly into the factory fog wiring. I'm going to use the red light up rocker switch that came with the rigids duallies on my light bar harness and mount it beside the steering wheel where the tilt/telescope lever is, so I don't have to hack the dash or anything. Saw someone else on here do that and it looked clean and he said the switch fit tight
    tblt44
    tblt44
  • Who's Online   5 Members, 0 Anonymous, 822 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
