Torsion bar confusion, need help!
Well something was bugging me ever since I installed my lift, My left torsion bar adjustment bolt was maxxed out while the passenger side was not even half way cranked. So I went and pulled my bars and swapped them side to side but it actually made it worse. Then I turned them around (still swapped sides) and same thing. Put them back in their normal spots and then turned them around again, but still nothing.
My stock bars are code YH, which have a torque rating of 5913. The bars I have in there now are GK which have a torque rating of 8615. I figured this would make a difference, because my stock bars were twisted. But I don't see how the bolt is maxxed out, with level keys!
Here is my actual question, Are the hex ends suppose to be flat with each other, end to end, or are they suppose to be offset on one side? Or maybe these bars just wont work with my truck? I want higher torque bars because I plan on getting one of those winch bumpers, without the winch part lol so I don't want to have to keep cranking it cause the bars are just too weak
Thanks all
I'm assuming they just aren't right for your truck, sounds like something is funky. I wouldn't worry about the bumper. Mine didn't pull the nose down or affect the ride, but it's only ~150 lbs
That's about how much the bumper I'm looking at weighs. Do you know the code of your torsion bars? Mine stock were YH and I miss the ride of it compared to the ones I installed about a year ago which were GK's
Sent from the side of the road...
UPDATE: got a set of stock bars (code YH) and used my level keys to get it to the height I wanted. Stock keys would have worked but would have been maxxed out. These are alot softer too, much better ride. Front fenders now measure 49.5" and the rears at 48 7/8"
    • So, my 2021 only gets radio updates, right? If that's the case, my radio is doing just fine and probably better off without any updates, especially considering the problems I've been reading about after updates were performed.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
