Differential question
I should probably know the answer since I just bought a 40,000$ truck but I don't lol... I remember reading about the z71 package offering locking differential, now does that come standard on non z71's also?? Mines 4x4 but not z71.
I know it came standard on my 14 Texas Edition LTZ 4x4 and on my 14 LTZ Z71 4x4.
Check the window sticker or the RPO sticker in the glovebox for code G80.
I am looking at my sticker right now; it is not listed as standard equipment, but I have it as part of the "Custom Sport Package", which includes the trailering equipment package-it is part of that, at least on mine. I also have the 4X4 but not the Z71 package.
dagwood, if there is some question about it, check the glove box sticker for the G80 code.
