Oh maybe that's why. I will unhook it again tomorrow for a while and see what happens.
I left the stock clamp alone. Tightened back up pretty good and seemed fine.
I love my magnaflow setup. I have 14" now, but had 18" before. I think the 18 is what your looking for. Here's two videos I made for comparison.
Dude! The top video is the exact sound I've been wanting. If you could please provide all the details on your setup? Mandrel bends, part number, magnaflow 5x8 oval? Thanks in advance. I'm in San Antonio, so I'm thinking of heading over to northwest automotive to have the work done.
Volant exhaust is the best i have ever owned.
I highly recommend this system. The growl is amazing!!! The videos dont do it any justice at all.
Sent from my Note 4 on Tapashit
Thanks for all the great information. Does anyone know how much louder the atak is from the s type borla. not sure which one to get. I hate to buy the atak and it be to loud and also hate to buy the s type and not be loud enough.
I new you would love it!!
I Fin love it. . That growl on cold start i can hear it from my room and makes me all giddy. This is what a truck is supposed to sound like!! So tired of the stock sound.... Trucks are supposed to rumble not sound like a prius.
Should brake in real nice with my trip home on Monday!!!
Love to hear some audio of your setup.
Awesome! Glad to hear you love your's too! Did you order the Corsa tip too?
Soon.... Ill make a video before and after the headers as well.
Sure did!!! When my sister sent me the system to work she forgot the tip but the volant one isnt bad for now.
Just wait until you see it first hand with the Corsa tip...you will amazed!! Damn sweet!!
Bad news is i might have to order another one .....
Because so far just from a video i sent my girl she wants it for her 2014 silverado as well....
Grate... Lol
Edited by Txjose
I want to hear it as well. It's not too agressive is it? I don't want an obnoxious sound but want it more agressive sounding than the GM borla. How is the Volant compared to the 14" Magnaflow? Do you have dual exhaust? Or single side out?
Grate... Lol
well....if she has the 5.3l, it will not fit (bolt right on) the factory tail pipe...
I haven't seen anyone with Volant r corsa do duals. Only single side out Edited by codman232
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 608 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
