What's everyone's thoughts on chrome or black running boards/nerf bars for my truck with no chrome trim?
I went with the all black, no chrome and really like the look.post-161843-0-08662200-1474772282_thumb.jpg
I went with black.
I went with black.
Do you happen to have a side shot of these? and what brand are they?
I think I'm leaning more towards black as well. Just can't decided between bars or running boards still. Too many choices.
Trying to decide on 3", 4", or 5" step bars. Truck will stay on stock 20s with a level when the tires wear out.
Just thought I'd throw in my update guys lol I repainted my emblems, removed the valence, added amp power steps, and I'm about to move up to a 4.5 suspension lift with tires :)
The rear block is out... Never liked that silly rake. Peeled all the trim, swapped colored door handles and skull caps on the mirrors as well black bowties. I got the colored mirror caps and handles for free so that was okay... And the 22's new in the GM packaging for less than half of new. Next is 2" shackles in the rear and 2" spindles up front I have had sitting in a box for a couple months. Chrome was the only way to get this truck... Chev has no options with this color and an LTZ.. It's a 6.2 which is the only reason I bought it.
Sent from my PURE XL using Tapatalk
Hey, how did you get the color matched door handles and mirror caps for free, did you swap them out with someone? I am looking at doing the same thing but no way want to or can afford paying $200+ for handles and caps! Thanks
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,317 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
