Does the Govt' Motor thing get old?
mike94silverado
the Ford dealer here STILL is running billboards stating "Built FORD Tough Without your Tax Dollars" all the Ford guys still call it Govt Motors... Seriously, It's old but since they are Ford guys you'll never be able to prove the facts to them my 2 favorites are--
DOE Loans Ford took are still "Tax Dollars" that they are using to "build" vehicles until paid in full.
If GM or Chrysler went under Suppliers would too ultimately causing major issues for ALL manufacturers
Not to rehash the bailout just seriously..... 4 years later and all the Ford guy can say is "How's dat Gubbment Motors truck workin out for ya?"
Well, if by old you mean that even the new fords require the operator to exit the vehicle and engage the front hub mechanisms, then yes its old.
I am not able to say exactly what I say to people who give that attitude. But the gist of it is that Ford took fed money too. Any Ford dealer who tries to capitalize on claims to the contrary are liars.
haha I still remember a friend trying to "enlighten" me on the superiority of those hubs when I was in Highschool driving a beat up hand me down Ram 4x4 with the automatic hubs that my dad gave me. He had it since new, never touched the 4wd, I think he had that Ford in every year for something Hub Related. not to mention that all I had to do was pull a lever :)
One of my friends was telling me all about how turning the hubs "locks the diff". Alright bud, sounds like you've never been stuck in a Ford before LOL.
Nothing more enjoyable than having to go scuba diving to lock in your hubs. My friends dad had the same maintenance issue as well. It got to the point where he got mad at us for locking the hubs and using the four cause it broke something every time. I don't know about anyone else here, but I'd rather not have to get out and lock the hubs when your 5 feet into manure from that tasty Alberta beef.
this dealer has a cult following.... it's not that the service is good, or the deals are good it's just that they've been here selling Fords forever and are so arrogant. I think the customers become arrogant too.. so he plays into that...
Not all Ford drivers are arrogant about it, I don't mind my lockout hubs they have auto or locked setting. Small price to pay to still have a solid front axle and not have IFS and CV shafts. IFS and CV's work great for my wife's daily driver but in a truck I want more
BTW I am not brand loyal at all, and have never referred to GM as Gubment Motors. I just buy what fits my needs the best.
Who even cares what anyone says about GM? It's not our company.. If some is dumb enough to even say "government motors" they are not even worth talking to anyway
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
