Rain-X on rear window
  • 3 weeks later...
  • Replies 38
I RainX all my windows and mirrors every 6 months or so. I use the RainX reservoir solution to keep my windshield clean and it also retreats the front glass. I rarely even have to use my wipers when it rains.
  • 3 months later...
  • 4 weeks later...
The secret to clear windows is "No Touch Auto Glass Stripper" from Napa stores.
Rain X works great on windshields because the wind is blowing off the water. I have used it over 30 years. Rain X causes the water to bead up on all the other windows, especially if not recently cleaned. Since I am 50 now, driving at night in the rain is more difficult with glare from other vehicles and a$$holes with their fog lights on in traffic. ( I got glasses about 2 years ago to help my vision, but I wear them 1/2 the time, so I am not that old or blind.) Light is refracted by all the beads, making it harder to see thru the glass and glare.
The Stripper will clean the glass and even remove Rain X, carwash wax, and hardwater spots. It allows the water to sheet off and not bead up. Sounds backwards, but it works. It is like using a claybar on your paint to clean it. Sounds weird, but it works. Mothers makes a glass stripper also. It is not as aggressive, but is easier to use. I use a 6 in buffer to apply as the No Touch is like a liquid polishing compound. Rinsing alone will not remove the residue as they say, so I usually wash the vehicle after treatment. Clean your windshield with it & a new Rain X or Aquapel treatment works even better.
Not sure? clean a side or back window. Strip half properly & just use glass cleaner & treatment on other half. Drive in the rain at night & the sheeting side will be easier to see thru.
A car dealer friend had a car with really bad water spots and the No Touch cleaned them all off. He does all his vehicles now with this stuff.
Good luck & post back your results with whatever you do.
Clay bar the glass before you treat it with anything, this will help with adheason of the product..
Good comparison video of aquapel and rain-x.
Hadn't heard of aquapel til now. I've always been a rain-x guy, but I'll have to try out the aquapel. 6.88 and free shipping on ebay:
http://www.ebay.com/itm/AQUAPEL-Applicator-Windshield-Glass-Treatment-Water-Rain-Repellent-Repels-/351099873659?hash=item51bf2ee97b&item=351099873659&pt=Motors_Automotive_Tools&vxp=mtr
Rain-Ex IMO is a waste of money. Creates a film wherein you can never truly clean your glass. The chemical properties were originally engineered for plexiglas and use on aircraft.
I put Adam's Glass Sealant on all my windows. Rained the next day, I didn't even touch my wipers. Back window was spotless as well.
  • 4 weeks later...
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
