My First Dent! Anyone else?
Defensive driving has saved me from many other people hitting me. Half the people out there can barely drive let alone defensively. Last night in the rain I watched a light turn red and a woman lock up her brakes and just slide right up to the light. Nobody was anywhere near her..
  • Replies 66
I noticed an imperfection in my front fender on the back of the wheel arch, has an outward dent...someone wasn't paying attention on the line.
As far as dents, was grabbing something out of the bed from the side...I leaned over, didn't think I put much pressure on the bed side, but left 2 small dents. Can't believe how flimsy trucks have become.
Very disappointing that the sheet metal is that thin on a GM truck. Not as bad as the new Fords though. The door panels on the Ford trucks was what mainly turned me away from them. They are paper thin like tissue paper and it waves when you open and shut the door even the mirror shakes like it is going to fall off.
You can have guns, you just cant shoot at unauthorized guests. It would be murder. From what I understand, that is ok to do in the States. ...Defending your home. Discharging a weapon in the city here is very very bad.
For handguns, you need a restricted licence, approved by the govt. And you can only take it to and from the shooting range, which you have a membership at. You also have to notify the police every time you do transport it.
No automatic weapons. Limited rounds in a magazine. A semi auto assault rifle is good as you get here.. With a plug in the mag, limiting its capacity. Even those are restricted..
Only some states...Castle doctrine... Only some states have it. I know off the top of my head Florida, Pennsylvania, Texas, I know there's more. Google can answer that
I guess I'm lucky to be living in Oklahoma. We have open carry here but I don't carry mine like that. I don't care about "advertising" the fact that I'm armed and I never leave the house without one on me. Makes me feel comfortable when I'm out with my wife and/or grand kids after dark. Lots of thugs and drug heads out there these days.
Tapatalk via iPhone 5s
I guess I'm lucky to be living in Oklahoma. We have open carry here but I don't carry mine like that. I don't care about "advertising" the fact that I'm armed and I never leave the house without one on me. Makes me feel comfortable when I'm out with my wife and/or grand kids after dark. Lots of thugs and drug heads out there these days. Tapatalk via iPhone 5s
My opinion....Who cares but this is it....It's too bad that people in the US need to feel like this. In order to feel comfortable one must carry a gun for protection - because everyone else does. I probably would as well if I lived in the US. Here in Canada I feel perfectly safe anywhere I care to go and never feel uncomfortable or afraid someone will harm me or my family and I live and work in one of Canada's largest cities. I'm not saying that it doesn't happen but it's a very rare occasion that someone will go ballistic by pulling a out a gun and randomly shooting. JMO
I think maybe YOU'RE the lucky one.
My 1st dent came from some idiot kid in a cavalier at a gas bar, swung his door into mine and didn't care... he's lucky we can't carry in Canada lol
    C. Hart
    C. Hart
  • Who's Online   2 Members, 1 Anonymous, 622 Guests (See full list)
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
