Since the seats are the same for the so called bench seat and buckets. Any swap out the center seat for a console or visa versa?...it's a 360.00 option..
I've been looking for a console to purchase, so that I cold do this. Just haven't come upon any for sale yet.
Tapatalk via Moto X
Can't do it very easy, I tried doing it, said F it, just give me a console truck
It seems like they get swapped pretty often around here. Here is one link
http://www.gm-trucks.com/forums/topic/150525-install-center-console-in-2013-silverado-lt/?hl=%2Bconsole+%2Bjump+%2Bseat
If you do a search for "console jump seat" and choose "forums" to search you'll get about 3 pages of results.
Mike
Your link is for a 2013. This would be different than a 2014.
I ordered a full center console from GM and I hope it fits in my single cab
What that cost you?
Sent from my Nexus 5
When I printed out the parts list it was quite confusing cause it tells you it comes with less than it actually comes with but when I get it I'll figure out what else it needs but the main console part was $457 and I know it's incomplete but I don't care about the cost I just want it to fit! Lol
It will fit. Can you post part numbers? I want to add one to my regular cab as well.
My 2010 had the jumpseat. I changed out the console from a wrecked truck that needed damaged parts replaced. Ended up costing about $500. I was under the impression that ordering a truck was more expensive. Not true come to find out.
Its ~$40k truck. Order one the way you want.
How did the swap turn out? I have one on order and am curious about how the 110v and USB ports hook up going from the "non-console" to the console?
    DaleB
    DaleB
  • Who's Online   4 Members, 1 Anonymous, 1,503 Guests (See full list)
    • If there are updates/fixes you want, you could pay to have the updates applied by the dealer.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
