18 minutes ago, zikronix said:
I counted 10 ribs on the mat is that correct? Have you had a chance to verify if that was indeed the new wireless charger.
10 ribs is correct.  I have not had a chance to verify other than counting the ribs and the part# on top.
Edited by b-garage
Here is what came with my order...
IMG_3862.thumb.JPG.202567ad2dbe703452c9ab912068c50d.JPGAlso rec'd the side plates, bolts, bracket and cables, just not in the pics.
What year model truck is this console for.? Johnny01
Sent from my SM-G935V using Tapatalk
If anyone is looking for the Console to swap out, here is the quote I just got from GMPartsNow.com  This includes everything to have the complete console and I did confirm that with them.
Also, if you ask for a quote, you will receive a code for 10% off.  From what I have seen of used parts, I think this is a hell of a deal.
Hold that thought.  There are two things I don't see.  I'm sending them an email about these.
Hold that thought.  Something I don't see is the rear trim of the console with the outlet.  I've emailed them to confirm if it is included in this.
Its there. Thats the console I ordered however @b-garage got the 2018 version and it was less money came with the 10 rib mat and i suspect the new 2018 wireless module. look at his parts list.
2018
I did not open the lid to confirm the wireless module part number, but I was able to lay my iphone 8 on there and it started charging. Left it on there for about 5 min and it seemed to keep linked up wih it.
Gmparts said this console should fit my 2016 Silverado but doesn’t guarantee it. Any one know ?
I was able to confirm with them everything that comes with the quote they gave me.  My quote is all inclusive.  B-garage had to purchase one part from another website and I think that changes what his quote came out to.  He will have to confirm that.  With being able to get the 10% off, it's a better deal than buying a used one as those whom have had them used quoted me $695-$800.  Including shipping and 10% discount it comes to about $695 brand new.
1st Pic: Console - 94199890
2nd Pic: Upper Trim Panel - 84092094
They highlighted which ones are included in these pics.  I had sent them the vin from a 2017 GMC Sierra 1500 SLT.
Scott, I believe 2014-2018 are all compatible with each other.  There may be slight variations due to brackets and so on that you may or may not have but, they should work.
I just ordered mine.  I'll take pictures once it arrives.  Mine isn't solid black like b-garage as I wanted it to have the same wood trim as the door panels and the brushed silver on top, which will look stock for my truck.
What does the new charging pad give you the old pad didn't.
Never mind... I found it. --3 coils instead of 2.--
Sent from my SM-N920P using Tapatalk
Edited by Lfod1836
5 hours ago, Scott Fish said:
4199890 comes back as a bad number.
You forgot the 9 at the beginning.  1st Pic: Console - 94199890
    DaleB
    DaleB
  • Who's Online   3 Members, 0 Anonymous, 1,100 Guests (See full list)
