Lol, thanks. There is always something....do it, you won't regret it. They look awesome
Debadged, still deciding on whether I'm going to keep the chevy badge on the back, cleaned and tire blacked. I love the Deep Ocean blue when it's clean...3facb1ecf2fa5e37f03437fa82083c1d.jpg
Sent from my SAMSUNG-SM-N910A using Tapatalk
Very true. I find myself washing my DOBM '16 all the time.
Curious. Which Autonation did you buy yours at?
And you have already swapped out color matched door handles?
Bought at the autonation in Gilbert off Val Vista and Pecos. The door handles were like that when I drove it off the lot. Guess I got lucky. [emoji4]
New tail lights having to get a new driver side one due to a loose wire, overall I like the look but will most likely have change the bulbs.
I say do it for sure! I've always been a fan of tow mirrors on stanced / lifted trucks. I'm wanting to get the 2015 HD tows for mine and color match inside and out with Klearz clear lens
Toying with the idea of tow mirrors again. Played with this in photoshop, what do you guys think? Yay or Nay?
looks good
I got tired of the front air damn getting mud and rocks lodged in it from the lease so I took it off. However, I missed the squared off look so I did a little cutting and trimming. I took out the center section and reduced the height of the area in front of the tires while following the contour of the damn. Let me know what you think.
Edited by Kjz215
Changed grille from chrome z71 to black surround honeycomb
Added Recon smoked projector head, tail and 3rd brake lights
Debadged Lettering
It was a good day....
Hey brother
Quick question. Does the recon lights come in different shades of tint? TIA
Sent from my SGS7
For you hunters... I tied into the factory bed lights and added a pair of led to the inside of my toolbox. They swivel and tilt. I also added a switch inside the toolbox so they can be on or off with the bed lights on, but won't accidentally stay on. This works for us since we back up to a tree, mount our portable tree hanger and get to work.
looks good. I add 39" led strip on the front of box, tie into cargo lights
Hey brother
Sent from my SGS7
I haven't seen them other than smoked
I would have to say the ride is not bad with 35 and a 3.42 with the rc 7.5 that my current set up your lose some but it not like most people say. I am also looking at 4.10 this winter but for now the 3.42 are doing the job. So don't let it stop going with a 35. You may be surprised.
Installed a wireless charger. Took about 30 minutes pretty simple and worth the money. Total cost 15 dollars well spent.
Sent from my SAMSUNG-SM-N920A using Tapatalk
What wireless coil did you use for it?
Sent from my SM-N900V using Tapatalk
Added Gm factory chrome skid plate and tow hooks...it makes the front end look more finished than the cutout in the chrome bumper to me.
Planning to do some more color matching and possibly powder coating the bumpers. Still want to keep the white / chrome theme with minimal black.
Those are sweet. What brand and how much were they?
5588674100d4b53b31bfa2243f87257e.jpg2d70c5075df98e6264fd68812db2df28.jpg152b5911d2df3142eb7293e68b1c8f3f.jpg
Flares. Spacers. Led fog lights and headlights and Led DRLs. Thought the DRL install came out pretty clean.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
