What to buy?????
blinn61
Hey guys I am new to the site, and wanting some in site. I am wanting to buy a new truck and debating on a '13 or '14. Pros,cons? Wanting a crew cab but could possibly go with ext. Money is key.
Beer, I would buy beer, maybe with a late 2013 born on dating. :cheers:
Because with beer, you can sit & type out WHAT YOU ARE LOOKING FOR. The above is pretty vague. Gas, diesel, cab size, towing or asphalt queen. Some details would
be helpful.
Well the mist towing bit would see would be maybe 7k, mostly a daily driver tho. I would haul anything from a load of would to a four wheeler etc. I am just looking for a 1/2 ton. Preferably a crew cab, thought about and ext cab for the little extra bed space. Also can't decide between the 5.3 or 6.2.
Sorry my phone is messing up the spelling.
And yes within a 200 mile radius I have found many 13's.
You can get the 6.5' bed crew on the 2014 K2. Would be stuck with the short bed on the 2013 GMT900. That said the 2014 5.3 is 355hp 383 torque while the 2013 5.3 315hp 335 torque. To get the 6.2 on the current models needs to be a top trim line of either LTZ/SLT at a $1995 option price. I bought a 2013 GMT 900 with a 6.2 & it was a $1000 option & was in a SLE package. Maybe in 2015 they will offer the 6.2 in lower trims, but not currently. The quick mpg driving that truck in & around town is roughly 14, was closer to 16 on summer fuel & less warm up/left running stuff.
The comfort, convenience & technology points to the new 2014 K2 design, but cash out of pocket points to the 2013 GMT900. You mentioned money is key & if you keep it long term 5/7/9 years etc. resale will be a wash vs what you saved at initial purchase.
is there even cash left on the hoods of the 13's? I know the dealers will cut deep on them but doesn't look like GM is offering anything anymore other than owner loyalty
Thanx for the info I have some deciding to do. I am thinking I'd rather have the 6.2. Which I cannot find in a 13 model but I don't want the top trim either.....
Around here they already have advertisements of something like 9000 off sticker on some of the 14s, so you know they went overboard with MSRP. 14s will have a lot of negotiating room I'd think.
That's what I've decided. I would like a 6.2 tho , but you can't have your cake and eat it.
if you haul a quad in the bed get the ext cab, my utility quad barely fits in my bed with the tail gate up but i love my crew
I am admittedly biased, but I would look for a 2013 6.2. Should get a good deal on one and a 6.2 with no afm. AFM is great for some and not for others.
You can get a crew cab with a 6.5' bed now. :thumbs:
I like the 14 look but I've found good deals on 5.3 13's play in it buy year best deal will win
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
