Crew Cab Std Bed Length?
How long is a the CC standard bed? I remember seeing GMs measurements are without the rear bumper. I plan on measuring my garage tonight to see if I would be able to fit one. Thanks!
  • Replies 39
I suggest test driving and taking it home and try pulling it in your garage. Best way to tell if it will fit.
Agree its best to bring one home. If I had to guess the truck is about 22ft
Sent from my SCH-I535 using Tapatalk
I measured my garage.. 20'6". When I close the door, you can't fit a notebook between the front or rear bumpers. 19.916' long seems about right haha
das a LONG truck. I have a double cab with the standard bed and the crew cab with standard bed is about 10-11 inches longer.
MIne would fit if I backed it in.
It's gonna be a bear to park at times too lol. I do like having a 6.5 foot bed though wouldn't want a 5-1/2 er myself I haul too much long stuff.
Take one home and try it is my advice. I had mine by a mile on depth I could fit a crew with an 8' bed if I wanted.
I haven't noticed any issues driving it. With the back up camera you can get in and out of pretty tight spots and the turning radious doesn't seem over bearing.
Great looking truck, hope by the time I'm in the market for a new one they are still makin the crew cab w/ the std. box in 1500 form. +1 on the level. Did it on my 07 and it looks so much better than the stock sitting GMT900's.
. I like this truck. The ratio off cab to box is just right
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,003 Guests (See full list)
