Ordered my 2015 DMAX Sierra today
Just had to share I'm really pumped. I got A CCSB white and coco, SLT, the usual options plus the rear entertainment for the kiddo's. I was hoping se one could tell me if the driver alert resets every time you cycle the key? I was hoping it could be left off and when I'm on the hwy I could turn it on. Is that the case or will it have to be turned off every time?
Congratulations! Sounds like one sweet HD! I am guessing you got a 2500 4WD? 18 or 20" wheels?
Be sure to post plenty of pics when it arrives!
  • 3 weeks later...
Driver alerts can be enabled or disabled in the menus. They don't "reset" when the key is cycled. You turn them on or off as you see fit and they'll stay set that way until you change the settings.
  • 3 weeks later...
Got a build date! May 5
Can you track it online?
Not that I know of. I've been totally reliant on my dealer which has been kind of a bummer. Seems like you should have app or at least a way to track it. I mean look At UPS FEDEX etc..... I'm dropping $60k can't I track my order somehow? Come on GM!
Congrats on the new truck. You can send an e-mail to [email protected] or message them on Facebook with your 6 character order number (get it from your dealer) for status updates. I think all they ask is you not inquire more than once a week as the status doesn't change that often.
You're going to love the '15. The new hydraulic body mounts combined with the new weatherstripping/seals makes for a really quiet and comfortable ride, but not TOO quiet and comfortable. Perfect balance for a 3/4 | 1 ton.
Enjoy.
Got built! Possible delivery next week! I also ordered a white color matched grill through the parts dept.
Towing 4500lb boat 70-74mph, headwind of 5mph
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
