2008 Sierra ball joint question
So i started experiencing a clunk when turning side to side while moving. Sounds like its coming from higher up in the front driver side so I am thinking the uppers are shot. I didnt check it yet but suspect ball joint. The truck just tuned 60k and are original. I read they are junk but will do the official check this weekend. A few questions about changing them.
Should I replace just the ball joint or get the arms as well? And the other question should I swap out the lowers too while I have it apart?
If it's just the ball joints, then the arm(s) can be reused. I would go ahaead and do all 4 ball joints while you have it down that far. Maybe try MOOG replacements??
There would have to be some significant damage to warrant arm replacments (IE:cracking, etc).
crepitus,
Hey there! I understand that you are seeking technical advice.As a customer service representative, I'm not able to provide much in the way of do-it-yourself information, so I'm glad to see forum members are beginning to step in with feedback. If you have any lingering concerns please private message.
Jennifer T.
GM Customer Care
Personally I'd buy the rough country replacement control arms. They have a replaceable MOOG ball joint and sell for about $249 a pair.
Well I checked them out and they still seem good. No movement that I can see. I guess I am going to have to look elsewhere.
Did you try torqueing the upper and lower control arm nuts? My recollection is that they need to be at like 140 lbs/ft. Anytime I got an alignment I would have to go back with a torque wrench and tighten them down (the upper arm bolts especially). I was getting a clunk when turning also.
  • 5 weeks later...
Its strange. It lasted a few days (it was extremely cold and icy) and went away. Haven't heard it since. Worry about it if and when it returns. I did check all that was mentioned above and it all looks tight.
that clunking could be coming from your stabilizer bar links. Check those.
+1 Everytime I hit a bump I heard a front end knock. turns out the bolt holding the stabilizer bar to the arm had snapped
