Rear sliding window factory add on?
Mine did not come with it so the front seat overhead console does not have the switch either. But I'm wondering what the chances are that the wires and connector are there and available/unused so if I procure the proper overhead switch/panel and sliding glass/actuator I could just plug them in?
I have had good luck in the past with adding options by finding factory plugs for options that were just never installed, installing them and just pluging them in
I think somone tried this after GM started building the resr slider again, but can't find it on the forum. They were not successful as I recall, but I can't remember why. I think it is very involved to install the split window and all of the hardware that goes in behind the rear seat.
Mine has it and was repaired under the bulletin.
Good luck.
And cost prohibitive...if you could do it...GM offers no kit for such. May check after market...but will not look stock
Didn't want one when I got it but now I realize how far a reach it would be from the front seat. Oh well. Maybe I'll get it from a junk yard truck sometime down the road.
My 2011 doesn't have it nor did my 2003. Never missed it and never used it on my Tacoma that did. Can't stand wind noise so I just assume use the AC.
From what the Chief Engineer of the entire GM truck division told me, it will be very expensive as in $2000 at minimum. If your truck is one of the higher end trucks the plugs may be in the harness. There will be a plug behind the rear seat for the window and one in the overhead console.
If anyone has a picture of the plug/location behind the rear seat please post it. It's a lot easier to check that first than it is the overhead console.
It is a real pita to get to the slider goodies behind the rear seat. Seat must come out them all the trim. took a shop guy that had done many about 1hr + to remove stuff to get to the heart of it and same going back. Scratched tint with all the trim in and out crap.
I use mine all the time to vent the truck, even with heater/air on. Not much noise and takes away the booming when the back to windows are let down a bit. Also use it to back up at night due to limo tint on rear glass. That said, if it was not there and knowing what I know about the amount of work and $$s, I would not try to add on.
Thanks for the good advise. It is extremely unlikely I'd do it then. It is probably likely that someone makes or will make a manual unit anyway.
I would love to do mine, don't get me wrong. Just not sure if the hassle is worth it.
I had one on one of my old trucks along with a boot on the topper. Never opened it.
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 696 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
