Replaces the vacuum system for your brakes with the 2500 system that uses the power steering fluid for assistance. Way better pedal feel and stopping power. I have a how to for it from a few years back, probably buried in that section by now
I think I saw the How-To whenever I was cleaning up that section. I'll have to check it out.
once you go hydroboost all other brakes will feel wierd to you lol.
Haha! I just looked at the write up. I may have to do it later on, sounds like a nice mod. You can never have to good of brakes.
I have to go back and add to my list. I forgot about replacing the catalytic converters. Im not sure which ones to go with though.
Edited by Daryl Z71
Here are the brake lines. They're actually cheaper then what I thought they would be.
Edited by Daryl Z71
I think I paid $120 for the 4 inch extension kit, came with all 5 hoses, for my 02. I got mine through Goodridge I believe
Never heard of Goodridge. Is that a local parts store?
No its the name brand of the hoses. I think they were the only one to offer them for my truck that were extended
Ohhhh I see. I've searched for lines before, and these were all I could find for mine. I thought for sure they'd be $150 or more.
Worth the cost and effort honestly
I've never tried a set before. Do they make a difference? I bought a set from Wilwood for my old Z28 one time, but I never got to try them because they didn't fit.
Improves the pedal feel, supposed to improve braking distance bc they claim the hose doesn't expand before sending fluid to the calipers. Not sure if I buy that, but I needed longer lines for the 7 inch lift anyways
Well, for the price of these I'm not afraid to try them.
Edited by Daryl Z71
Once i get done with the interior on my truck im going to finish the exhaust. I was looking at Magnaflows cats, you can get them as a stand alone weld/clamp in or with all the pipe from the manifold to where they clamp on to the factory exhaust/cat-back, and come in stainless. Kinda pricy for my truck but i like the fact i can just bolt them in and go.
Edited by cjb321
    • I am new to this… but I saw some of your replies to another person doing the same as me… trying to replace the temp control actuator in my 05 GMC SIERRA, And can NOT get to it… how do I get the center console panels off, do I have to take ALL of them off to get to it? 80481681120__F97CE005-C5E5-4FBF-9589-1388214E3586.MOV
    • I will be one of those "blinded". One, I like new shiny things. Two, I've never kept any of them beyond the 3/36. Three, I don't finance anything. Four, yep, it's a waste of money....so,what? I'm doing my part of keeping automotive industry going and keeping my neighbors, most of whom are in it, employed. 😉      By the way this is the "signature... ¬
    • Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least. My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing. Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit. You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling. Marv
    • davester, Thanks for the response, how ever, I think I am now a bit more confused than I was before I posted - - After I posted, I actually found a YT video of a guy who replaced his Module (above tire) and he only disconnected the ground cable of the battery, but you describe rubbing the two cables together after disconnecting. I presume that is to do as you describe and eliminate any residual energy? - When I picked up the Module (between my posting and reading your response) from the dealer, I specifically asked about any re-programming and he stated it was not necessary as it was simply plug and play. Don't know how knowledgeable he is, though. - The video I watched also showed the Module plug to be difficult to "unlock" and remove, but there was no mention of silicone, although the video did show a bunch of dust/dirt in and around the plug (old truck) during removal. Are you talking about silicone that was applied by the factory, or silicone that you applied prior to plugging in? Thanks again, Marv
    • Looking for a clean, factory-style lighting upgrade for your 2022+ GMC Hummer EV? M&R Automotive's 40" Bumper Light Bar PRO features a vehicle-specific, bolt-on design with no drilling or cutting required. Choose a bright white or yellow main beam, both paired with an amber DRL backlight for a sleek OEM-inspired look. The kit includes a curved LED light bar, powder-coated brackets, and all necessary mounting hardware.    Learn more or order yours See how it installs and looks on the vehicle:
