Marvel Mystery Oil
captras
I have read many opinions, good and bad, about this. I was wondering if anybody uses this in the new trucks? Good, Bad...Indifferent. Marvel oil or snake oil?
Just follow the recommendations the owners manual provides.
Would you really want to risk your $30k+ investment on something with MYSTERY in the title?!?
I actually know someone who put that garbage in their engine. It lost oil pressure soon thereafter and never recovered.
I'd suggest finding new sources of advice if someone is touting that crap.
What would be the reason to use it in a new vehicle?
Please don't use that stuff in any modern fuel injected engine. It may have done some good on older engines... say from the 70s and 80s, but it has no place on any modern vehicle.
It is a really good product for what it was made to do. I have some air tools that are 35 years old that have never been used with out a couple of drops being put into them the first thing before they are aired up every day. But as far as using it in or on your truck I think that I would just say no. Just my $0.02. :jester:
MMO can be a good additive for older 'old' school engines both oil and fuel. Seems to do no harm if used in moderation.
In oil,(1/2 qt MMO per 5 qts oil) it acts a very mild cleaner. Cleaning some types of deposits - I have actually used it and it help with sticky lifters ages ago. More aggressive cleaners could release too much crude too quickly and clog filters.
In gas, (4 oz MMO per 10 gallons) it acts a upper cylinder lubricant. Gas it actually very dry. Pouring in the fuel tank helps lubricate the fuel level, fuel pump and injectors.
Now with direct injection, not sure how they will play out.
for a 55 Chevy... yes. But for any newer vehicle.. you would be a fool to add anything to the oil.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
