How to find Build Date
I know this topic has been covered, but I've done numerous searches for "build date" with no luck. Googled it also.
Anyway, how do I find the build date for my 2014 Silverado?
Thanks!
  • Replies 41
I'm assuming you mean other than the month/year?
Right... I purchased the truck on March 31. Wanting to know the date it was built.
Manufacturer: Chevrolet
VIN Characters: 17 (beginning with MA6...)
Decode:
7th character represents the MONTH of Manufacture
9th character represents the YEAR of Manufacture
Month Codes:
A = JAN
B = FEB
C = MAR
D = APR
E = MAY
F = JUN
G = JUL
H = AUG
J = SEP
K = OCT
L = NOV
M = DEC
Year Codes:
A = 2010
B = 2011
C = 2012
D = 2013
E = 2014
F = 2015
G = 2016
H = 2017
J = 2018
K = 2019
Decode:
Month Codes:
A = JAN
B = FEB
C = MAR
D = APR
E = MAY
F = JUN
G = JUL
H = AUG
J = SEP
K = OCT
L = NOV
M = DEC
Year Codes:
A = 2010
B = 2011
C = 2012
D = 2013
E = 2014
F = 2015
G = 2016
H = 2017
J = 2018
K = 2019
Perfect... exactly what I needed to know!
Hi Luster,
Please feel free to send us a private message with your VIN and an email address and we will be glad to email you your vehicle build sheet, which includes your vehicle build date. We look forward to hearing from you soon!
Kristen A.
GM Customer Care
Decode:
Month Codes:
A = JAN
B = FEB
C = MAR
D = APR
E = MAY
F = JUN
G = JUL
H = AUG
J = SEP
K = OCT
L = NOV
M = DEC
Year Codes:
A = 2010
B = 2011
C = 2012
D = 2013
E = 2014
F = 2015
G = 2016
H = 2017
J = 2018
K = 2019
How about GMC? Those codes don't jive with my VIN.
I would check my door, but they must have used disappearing ink on the info labels??? when it was detailed at the dealer before I took delivery, they must have wiped the numbers right off. Not a very good idea from GM to not protect this obviously easy to remove ink. My only complaint is valuable information as far as build date, tire pressure information is not here on my truck.
Thanks!
Hi Luster,
Kristen A.
GM Customer Care
Thanks Kristen. I'll email you the VIN as soon as I get home from work.
Thanks!
Try characters 8 and 10. Mine are C and E (March 2014)
8th digit is your engine "C for L83engine"
10th digit is year built "E for 2014"
Don't thing you can get month built off of vin just looking at it. Dealer could run it for you.
Go to page 25 of this link.
https://service.gm.com/dealerworld/vincards/pdf/vincard14%20LDT%2008-13-14%20r1.4.pdf
Bad info above. You can only get the year from the VIN.
I guess the GM robots missed my disappearing ink post?
Dumbest damn thing I ever seen on a vehicle!
Thanks for the replies. I will PM the GM rep.
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,150 Guests (See full list)
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
