2014 steering binds in turn
Well.....thought I would follow up on this....my truck is fixed. I now have a new Rack and Pinion assembly on my truck....works perfect. I now have over 20k miles on her.
Dug
Only use 2HI in dry conditions. Some people will tell you that its OK to run around in auto all the time, but it's not good at all.
I only use AUTO for scenarios where I think ill need extra traction on a take off, or a turn in wet, damp, snowy conditions. Having it in AUTO while cruising around in dry conditions does not help anything as far as traction, it can only hinder gas mileage and add excessive wear to the transfer case and front driveline.
the AUTO system is NOT the same as a full time All wheel drive system like the previous gen Escalades, Yukon/Sierra Denali's, Subarus, Audi's etc. It is a PART TIME 4 wheel drive. That doesn't mean its OK to run around in it all day long. Use it the same you would 4HI. At lower speeds and for shorter time periods.
Its perfectly fine to flip into AUTO at a stop sign, use it to get extra traction on take off, then flip it back into 2HI while going the speed limit. That is how it was designed, to be flipped on/off on the fly.
If this is something you already know, then sorry for repeating it. But hopefully someone who didn't know this info, now does.
Good luck!
thank you. I am new to the whole 4wd/2wd thing. This helped a ton.
Glad to help amigo
  • 1 year later...
Hey all:
I have this same exact problem with my 2014 Silverado Z71. I don't drive it a lot, so I only have about 14,000 miles on it, but I have this exact problem when turning right around ramps and freeway curves. I have taken my truck to the dealership and they cannot replicate the issue, so they won't do anything. No recalls or bulletins on my truck that are related to this issue.
Not a 4x4 Auto, High, Low isssue...just 2-wheel drive, clear/dry roads, normal driving. Sort of freaks you out when your steering doesn't recenter without moving back past a binding point.
Have you resolved anything with your problem. Any guidance? Did customer care help at all?
Still under warranty. Just don't want to get stuck with this problem on my own nickel, so I hope someone else has found a solution with GM.
Thanks!
Bulletin on this subject:
http://sandyblogs.com/techlink/?p=5126
UPDATE: Steering Column Noise Conditions Repair
postdateicon.pngSeptember 15, 2015
A grinding or popping noise or a binding feeling in the steering column when turning left or right may be experienced on some 2014 Silverado 1500, Sierra 1500; 2015 Silverado, Tahoe, Suburban, Sierra, Yukon models and Escalade models equipped with a tilt and telescoping steering column (RPOs N38, N37).
These conditions may be caused by the lower column bearing housing assembly being out of position (Fig. 4) or the upper intermediate steering shaft to lower column shaft bolt and nut may be contacting the inhibitor/shifter cable bracket. (Fig. 5)
TIP: Do not replace the steering column for these conditions.
Fig. 4
Fig. 5
To correct either condition, repair the steering column assembly by replacing the column lower bearing adapter assembly and retainer. Refer to Steering Shaft Lower Bearing Adapter Replacement in the appropriate Service Information for the complete repair procedure and torque specifications.
Here are some highlights of the procedure.
Remove the steering column as an assembly from the vehicle to remove the steering column lower bearing adapter assembly from the column. (Fig. 6)
Fig. 6
Depress the retaining tabs using a flat bladed screwdriver to remove the lower bearing assembly from the column.
Install the new steering column lower bearing adapter assembly and a new steering column lower shaft retainer to the column by first measuring 154 mm (6.06 in) from the end of the steering column lower shaft and drawing a line around the shaft. (Fig. 7)
Fig. 7
When installing the new steering column lower bearing adapter assembly to the steering column, make sure the bearing adapter is fully seated with the retaining tabs secured.
Install the lower steering column retainer to the measurement mark and verify a 3–5 mm (0.12-0.20 in) gap exists between the lower shaft retainer and lower bearing assembly. (Fig. 8)
Fig. 8
  • 1 month later...
I have a 2015 Silverado 1500 with the same steering binding issue. It's been doing it since I bought it in July. I now have 6500 miles. Only happens when turning to the right a highway speeds. The steering actually binds to the point where I have to physically center it. Turning left is fine. Seems to be related to the length of my trip. The longer I drive, the more it happens. On short trips, it's fine. Low speeds, it's fine. Feels like it must be something to do with the rack and pinion unit. I know the rack and pinion is electric power assist. I bet that's where the problem is...the unit gets warm and begins to bind. Any service bulletins on the rack and pinion??
  • 1 year later...
I am having the same steering sticking to the right and driving off the road if not forced back, I have been trying to get a video but had no luck, the link that was posted id not working anymore, is there another link showing this problem? thanks.
My 14 did this too, got out to look it over and saw nothing broke or hanging, got back in to start it and it decided to drive itself in Park!  had the dealer pick it up right away, they found nothing wrong...so i traded it.
I know this post is like 3 years old at this point, but pretty sure there is a recall out on this issue. Not sure if specifically this, but I just got an alert for my '14 that there is a recall for P/S stuff. Get it checked out if you haven't already.
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
    • Let's pivot this back. Someone said they wanted pictures.   Even better, there's already video. Pre-prod prototypes are already on the road and they're letting the press drive them.   JerryRigEverything did a good review. I really enjoy his content and EV adventures, so I was thrilled when he had the chance to review a Slate:
    • The Charger EV was stillborn. Wrong car at the wrong price for Dodge's intended audience. Now at a good price with fire-sale discounts, and still not selling, it's still very much the wrong car. Again, Dodge's intended audience. I believe a lot of Stellantis' EV blunders were all under Tavares' regime at Stellantis...the board convinced him to move on. Neat car, just wasn't received on the level that would sustain mass production.   Dodge is headed in a better direction for its core business. I didn't think there was anything left to get excited about re: the Durango after its 15 year run, but they're just now releasing a 392 version that should price out in the low 40's. Nicely done. I'm not sure I would touch anything Stellantis makes with a 10' pole these days, but the Durango is still mostly parts designed like 3 parent companies ago so maybe it's still OK?
