New Ride!
SnakeEyeSS
Guess. Except for Ryan, he already knows(yup, I'm buying tomorrow)
Sadly, no pics until I take some, the ad just ended on Craigslist.
  • Replies 46
Nope, that guy is up a river from raising the price before I looked at it.
Hint:
I'm going to try and race it on Sunday.
Not a chevy think obsolete car company :lol:
Ryan
When I was on a test ride the attention we got was ridiculous, partly due to the attention a car that is too loud gets. I mean too freaking loud, like three Harleys at WOT. Never thought I would want quieter and more restrictive mufflers on a car
GTO?
Daryl's answer plus your answer and your almost there
    Dom Colussi
    Dom Colussi
  • Who's Online   4 Members, 0 Anonymous, 693 Guests (See full list)
