Glad the guy is ok, sucks to see a 45th anniv edition crumbled, yeah it's just badges and stickers but i've always been a fan of anniv editions.
post-134634-141523811911_thumb.jpgpost-134634-141523814959_thumb.jpgpost-134634-141523816879_thumb.jpg
I put the C7 away. Only put 3500 miles on her this season, but now i have my silverado to play with the whole winter. Come next spring the c7 is getting a supercharger! Hope the winter doesnt last as long as last year
What supercharger are you going with?
My next mods are hi flow cats and maybe headers. Hope to win a set of flowmasters @ 50% off next week.
I really like that color combo on the Vette. Can't wait to see a silver Z06, I don't think any of the show cars have been anything other than yellow or blue. Dang, if they just had a back seat :lol:
Can't wait until Dyno Day!
I was listening to a car cast, they had a SVT fanboy on. He was mentioning with a tune, CAI and exhaust the SHO makes well over 400. And, they are pretty easy to find for low 20k with low to below avg mileage.
Peaks my interest for a daily and kid hauler, having AWD and all.
Edited by SnakeEyes
Probably go with a ECS or A&A, they both seem reliable and put out about the same hp
The back wheel bolt holes (on the wheel) were drilled out to fit 5/8" studs. They don't have a 5/8" adaptor. The studs are only threaded for the first inch. They said they had never seen anything like it, and the lug nuts were machined down flat, not conically, and a flast washer was fitted between the but and wheel surface. I need to get new studs and lugs for sure, they were sure if I can safely put regular lug but on again with these wheels the way they are drilled. If I can find these wheels with 5/8" holes I will be fine, just swap them.
OK, those wheels are made in 5/8 stuff sizes, so I think I'm going to see if I can get 1/2 studs I'm that spot, but since there are 5/8" stud NOW, not sure of that is possible.
Most likely require new axles, I would be a bit nervous running 1/2" studs with that kind of horsepower especially if you have some sticky shoes on her
To be clear, I believe new lug nuts will fix the wheel fitament safety issue.
They were flabbergasted over the trouble someone went to to rig those lugs, when they probably just needed different lug nuts. They wanted these wheels to fit, so they drilled the wheels, and custom machined the lug nuts flat instead of conical. And found a washer to fit. There is a little play, and I think I just need to get conical lug nuts again, as the cone will fill the "gap" between stud and wheel. These current flat nuts don't, causing the play. Bizarre.
A customer came in toward the end, and really like my theory the builder ran out of money and patience, and that's why most of the car is top dollar, but some small pieces were "made to work".
The stud change is so they could dyno it, the way the thing mounts, it needs so much distance to fit to the hub, and my car is mini tubbed with a narrowed axle. Less room to mount the machine. They said it would work if I had fully threaded studs, a modified(literally custom made) wheel spacer(which would probably be ridiculous to have made just for this), or revert to standard 1/2".
The good things is the main guy said he is sure the car makes well I over 500 to the wheels, so I have someone else who agrees with that.
They said many times that is was a very nice car that looks very well built(besides the strange nuts)
Edited by SnakeEyes
Looked around, flat lug nuts with washers isn't uncommon, several drag wheel companies make them for drag racing. It just wasn't done correctly in this instance.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
