There is no question the "booming" noise is worse in V4 mode, but it still notice it in V8 mode as well. My take on it is that any and all "impact" forces that go into the chassis and body result in noises being generated. So, he extra vibration generated in V4 mode makes the situation worse. As does the stiffer tires and suspension. And so on, and so on. Basically, a bad situation made worse.
In addition, I did some testing on the highway by putting it in manual and dropping a gear and the "Buffeting/pressure" did not change. Haven't played around with manual mode at lower speed to see what it does to the booming, but I did seem to notice that when I accelerate hard, the booming seems to go away?? Hmmmm. Be interesting to take a test drive with the exhaust flapper valve forced open.
Most of what has been posted points to GM thinking this is a vibration issue. Based on my experience, I agree. Just search my posts here and you'll see I was able to reproduce the pressure and buffetting at low speeds by exciting the chassis. I started off with the buffetting at 39 MPH but it would occur at other speeds too. BTW, replacing the entire rear end practically eliminated it at 39 MPH but as I said it reared it's ugly head at other speeds. I would assume GM knows this is a real I issue but is quietly sweeping it under the rug, well, because they can. My bet is that the 2016's will not have this issue (or it will be less noticeable) but we'll have to wait and see.
Edited by ateam_burb
Question ....
Is their a aftermarket shock manufacture that makes replacements for the Magnetic ride controll system? There is NO doubt in my mind these OEM shocks are complete junk! And I feel this is where the problem starts. I'd be willing to spend the money to try this. I just can't drive this Escalade anymore. It's not worth the aggravation, and the pounding pressure in my head.
AGAIN.... If your reading this thread and your un desided weather to purchase a new GM SUV... I would WAIT! We are on our 2nd 2015 now. They both have been a completely disappointing!!!!!
Oh yeah. Had our meeting yesterday with the GM field engineer. Went exactly like I thought it would. He said he could hear a touch of the booming sound, but ours was one of the better ones he's driven. Total corporate BS answer. they want to rip the car apart and do the cross members in the roof. I asked if anyone has acknowledged this has helped the problem, for I've never seen anyone online that has stated an improvement.
As for the low speed lugging and bogging. He said that's Normal in V4 mode. Sorry Sir, that's BULL CRAP! It's not normal for any car or truck to bogg, shutter, lumber along then smooth out. Tell your coworkers back in engineering to fix these new POS 8 speed transmissions, and the computers that run them. Even better, how about TESTING these things before selling them to the open public.
So basically to conclude my rant. F-U GM! I'm so 100% tired of dealing with this complete piece of crap you sold us.
Edited by TOBTEK
Question ....
I did a search and there doesn't appear to be an aftermarket replacement for the shocks on the vehicles equipped with the Magnetic ride suspension. However, Bilstien does list shocks for the non-Magnetic ride version in the 2015's and a set of 4 is around $400 depending where you buy them. On my list of things to try eventually is to through a set on and see what happens! I'll tie-wrap the wiring harness for the electronic version something and see what happens.
But, I've had two 2015 rentals (while ours was in the dealership) that did not have the Magnetic ride suspension and both of those had all the same noises as ours. So, I don't think it's the Electronically controlled damping itself that is the problem. It certainly could be the base damping used in both versions of the shocks, though. Could be too stiff.
I read an interesting article on shock absorbers on the weekend. Seems that the latest and greatest in shock absorber technology is shocks that dampen immediately upon any movement, instead of older designs that had to move many millimetres before getting stiff. Hmmmm. Perhaps In GM's quest to modernize the ride, they have installed "too good" a shock absorber? There is no question the wrong shock absorber can mess up a suspension's performance and the ride quality big time. And more refined the suspension, the more this is the case.
The other thing that concerns me is that GM made the springs too stiff. Again, trying to give a more solid ride and remove the "lumbering" feeling of a large, body-on-frame pickup based vehicle with a high center of gravity, they may have gone too far.
So, softer tires, softer springs, and softer shock absorbers.
I totally agree that there is a big problem with the shock and spring setup for both the Premium Smooth Ride and Magnetic Ride vehicles. Add into that some 20" or 22" wheels and it's even worse. A bad expansion joint will set your teeth rattling. It will also excite the roof section to give you a quick baffling sound to accelerate your headache. But if you're going to push back at Chevy with how miserable those suspensions are then you are only going to hear " that's how we built them. Sorry if you don't like the suspension but they're performing to specifications."
If you want your money back you need to take a copy of the GM Service Bulletin PIT 5318 and a copy of your state's Lemon Law into your dealer and say "we're going to fix this baffling sound that GM admits is a problem. And if you can't do it in the time/attempts as spelled out in the Lemon Law then I will demand a refund." Any service manager that has tried this repair will probably dump this in GM's lap at this point because he knows it's a hopeless cause. GM will send out an engineer to measure how bad your vehicle is and if they think they can get away with pretending there is no problem. Read the bulletin as it explains many of the different things that excite / "oil-can" / baffle the roof. Stay tough. Document your calls and conversations. They can't fix them. You will get your money back.
It may be helpful to some if when you mention something like "GM Service Bulletin PIT 5318", you provide a link to the document.
Hi all,
We requested a buyback from GM several weeks ago and all we get is the run around. We've been told the District Manager would be calling us on 3 different occasions. This hasn't happened for 2 weeks. We will be hiring a lawyer.
I wonder how quick the judgment will be when I drag my 4 little kids into court.
$70k for a vehicle that gives you headaches and vertigo. They better hope this doesn't turn into chronic inner ear problems for my wife, or I'll be getting a lot more than my $70k back.
Hi all,
Isn't it crazy that we all have been dealing with this nonsense. We all spent a ton of money in good faith for the betterment of our families, and we've all been put through the ringer. I ride in our new Escalade little to not at all any more. It's just not worth the annoyance, headaches, and the arguments it creates between my wife and I. She still thinks if there was a known problem GM wouldn't be selling theses vehicles.
Sure wish Toyota would step up And build something more modern then their out dated Landcruiser or Sequioa. I hear the new Infinity is really nice, just don't care for the look of the thing.
Edited by TOBTEK
GM Service Bulletin PIT 5318 is copied on Post 113 of this Topic. I think roughly page 8. There is an updated PIT 5318A that has the additional note regarding other "Inputs that can excite the roof". You would need to ask your service manager for that version as I have not yet seen it posted.
Something interesting about PIT5318. I have found a couple of websites with GM service bulletins listed. While it shows PIT5318 listed, the link is always dead when I try to open it. All the other links to various bulletins work, but not that one. And, on a couple of different websites. Weird, eh? I doubt it's a coincidence. Perhaps GM is trying to avoid it getting out because of legal action coming at them?
They're hiding it because of the millions of dollars of buybacks they are forced to do. And let me tell you they watch this website closely. They want nothing more than for this topic to quiet down. That's one of the reasons you haven't seen the GM responses anymore.
Actually, they have admitted it (indirectly). Their customer satisfaction surveys has a long list issues which you may have experienced (water leaks from antenna, buffeting, wind noise...dissatisfied with the radio, etc.). So, they know of the complaints, problems and issues. They have made changes in the 2016 models to 'fix' the problem. Back to the survey. Good luck getting a buy back for that problem if, on the survey, you say it isn't a problem.
Supposed to pick up my Yukon XL today from Liberty Buick/GMC. They have had it for 3 weeks. They did the roof fix and it did not solve the problem, then they installed a new exhaust. When I asked the service tech if the booming/buffetting noise was gone he hesitated and said yeah.....
Going to take a long test ride, if it's not fixed I'm done with this vehicle.
I hope GM will step up and buy this vehicle back. Trade assistance into another Yukon is not going to get it. If GM does not want to help, I'm off to a Ford dealership and will trade my Yukon for a Expedition and take the hit.
I'll keep you posted.
Quick shout out to the service dept at Liberty. Robert and Rocky have been great to work with.
Hi Guys,
Sorry to hear about the difficulty you guys are having. It's sounds both awful & extremely frustrating.
On Thursday I placed a deposit on a 2015 Tahoe LT, and I am supposed to pick it up this week. Afterwards, I was poking around and I found this thread. It is concerning to say the least.
It's seems this is having to some, and not ALL vehicles? Is this correct? Are most effected or just a small sample?
But most importantly....
What exactly should I do to test my vehicle on a test-drive PRIOR to signing the contract? What is the best way to test this and what should I look for prior to agreeing to the purchase? I have small kids, and certainly wouldn't want to put them in a vehicle that would make them uncomfortable.
Thank in advance.
Can you elaborate on this? Are you talking about the 2015i models or upcoming changes for MY2016? There are several people here with 2015i's that have the buffeting. Thanks.
    Smitty462
    Smitty462
  • Who's Online   4 Members, 0 Anonymous, 572 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
