Dash rattle solved
jeffsig
I went in for an oil change at the dealer, and i showed my service guy. Of course, he didnt know what it was or had never heard of anyone else with the rattle. Said he would look the piece up and let me know what it was.
When my truck was done, i got F out of there..he must have been on lunch.
  • 4 weeks later...
  • Replies 58
Well, I had finally had enough and pulled out the small clip in my sunglass holder and.........no more rattle !!
Also, try this (you never know):
Great Vid! By the voice I'd almost swear that was Blake Shelton =)
the whole thing comes out. Leave the other one there that's next to it. The sunglasses door still stays closed without that clip. See attached pic.
I was waiting for someone to do this! Gonna happen on mine in about 5 mins.
How'd it go?
I want to pull this clip to get rid of my rattle but I don't want to pull it and then not be able to close or open my sunglasses holder.
I had the same concerns as Ive only had my truck a few months. But finally removed it and everything still works fine. Rattles are gone ! Just make sure you remove the smaller clip closest to the rear of the vehicle.
How'd it go?
Pulled it out. holder closes fine. No more rattle!
Can someone explain to me how I can get my sunglass holder to close again? I ended up taking off the plastic piece with the metal pin, then I put it back in, but now it just slides back and forth on the holder without locking it closed. Does the pin go into something? Right now it just rests on top of the plastic part with all the grease. I can't keep it closed now?
To see a clear picture of what I'm talking about, go to this link and see the first post showing a picture of it.
Link: http://www.gm-trucks.com/forums/topi...rattle-solved/
I also posted this question on another gm-trucks.com thread to get an answer. Right now, I'm not getting any luck.
Link: Sunglasses Holder - 2014/2015 Silverado & Sierra Issues, Troubleshooting, & Recalls/Service Bulletins - GM-Trucks.com
Also posted in the dmaxforum thread
Link: 2015 Rattle Bucket
  • 1 month later...
I recently traded in my 2014 for a 2015 (couldn't pass up the price) and the clip doesn't rattle... at least not yet, but they changed the piece to one that is half the size of the 2014 model....
Still unsure what its there for.
  • 1 month later...
I pulled that little black plastic pin out of the sunglass holder today as I was having the same rattle, but it didn't seem to make the rattle go away. It is still there and sounds the same. It is definitely coming from the sunglass holder area. Anyone else have this issue? Thanks in advance!
Sometimes noises play tricks on you. I solved another one on the drivers side. I pulled the fuse panel off on the drivers side and the fuse panel itself was moving slightly over rough roads. I shoved some foam blocks around it and quiet as a mouse now.
I pulled that little black plastic pin out of the sunglass holder today as I was having the same rattle, but it didn't seem to make the rattle go away. It is still there and sounds the same, Maybe even worse. It is definitely coming from the sunglass holder area. Anyone else have this issue? Thanks in advance!
Does anyone have any insight into this? I have pushed the holder up, shoved double sided tape in there, and nothing. It is driving me nuts!!!
  • 1 month later...
I Link: Sunglasses Holder - 2014/2015 Silverado & Sierra Issues, Troubleshooting, & Recalls/Service Bulletins - GM-Trucks.com
I did the same thing. The key is that there is a small cone shaped spring that goes between black plastic lever (with metal pin) and the plastic housing. When you removed the wrong piece it likely sprung across the cabin and landed on the floor. Mine was in the deep grooves of the rubber floor mat, driver side. I thought it was gone for good. The small diameter side of the spring should face toward the driver side of the lever post and the fat portion towards the grey plastic sunglass holder housing. That slight outward pressure on the latch is enough to grab the pivoting sunglass holder itself and cause it to latch properly.
Regarding the correct piece which no one knows the purpose, I jammed some electrical tape in the slot to keep it from moving around.
  • 11 months later...
2014 GMC Sierra 1500
Ok, I had the same popping noise in my truck. It was like a ticking noise coming from the right side under the dash. It seemed to go away sometimes, but other times it was very annoying. If you push on the dash above the glove compartment, it would go away. I took both glove compartments out and it seemed to go away. I put them back in and it would come back. After dealing with this for over 2 years, I finally took time to troubleshoot the noise source. If you take the glove compartment out and look above the to compartment, you will see a round metal bar below the airbag. There is a screw that connects the plastic piece of the dash to that metal bar. Put some felt or tape between this connection and that will solve one of the problem areas. Another source of the tick was below the fuse box on the right side of the dash. If you pull the cover off the fuse panel, you will see where the plastic dash part is connected to the chassis by 2 large bolts near the bottom door hinge. This is where most of the noise came from. By loosening these 2 nuts and putting felt or masking tape between the connection fixed the problem for sure. I hope this information helps someone. It drove me crazy!
    HWN808
    HWN808
  • Who's Online   3 Members, 1 Anonymous, 866 Guests (See full list)
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
