I installed AVS ventshades (in channel) within a week of getting my truck and yes I followed the directions.
It has been a couple of months and last week while the truck was parked all week, three of the shades fell out.
Any advise on how to get them to stick better? If not I might just take them off.
I use the EGR in channel and just transferred them to my new Silverado. I used goo gone to clean off the old tape and used double sided scotch tape to apply. Holding strong! Hope this helps.
How did they fall out when it was parked. Were the windows open? One of mine had a problem so I called AVS and they were very helpful.
What did they tell you to one of mine fell out too Norm
One of them was just hanging so I could see that the sticky stuff was still in the channel but had come off of the tabs. It was not a hot week (mid 80's) but I do have a black truck. I think the truck got hot and the sticky softened and the shades slid down. It was the two rear and the passanger was down enough that when I saw it I just pulled it out for fear I would loose it driving down the highway.
I took mine off and was going to call avs for a refund.. I even put extreme outdoor mounting tape on and they were still
always loose
The tape tye use is crap mine fell out the first time I put the windows down. They were dealer installed.
I put good quality 3m tape on them and they are stuck now.
All though they make noise when the wind jits them and scrap if the windows get dirty.
I'm getting some stampede for it and chucking the AVS ones.
Well this isn't good news. I just installed AVS in-channel vent visors on my truck 2 days ago. It seems like they're holding so far.
I can't believe yours fell out a couple months after installation. If they glue didn't adhere, how could they have lasted that long?
Edited by 14x4
Reading the amazon reviews it seems the tabs are not long to be pinched in the channel. I emailed AVS and they are sending me new ones.
im having the same problems with mine. my front drivers door and rear drivers door. the middle of the vent shade is coming down as the double sided tape is still "in the channel" and I can see the two middle tabs with no tape on it. im going to pull them off clean them and use 3m tape to see if that works... a little irked about it b/c I have only had them about 2 months and I had not heard of anyone having this issue with them like the weathertech ones. oh well.
what is the point of vent shades again? sounds like a bad idea from the 80's.
You can crack open the windows even if it's raining.
I have those sticky GM ones (glued on the door). Dealer installed and no probs so far.
Maybe that's a better option than the "in the channel" ones.
so long
j-ten-ner
Maybe they (AVS) changed something recently.
I've had their in-channels since April and no issues so far.
Edited by glc
    DM22
    DM22
  • Who's Online   0 Members, 0 Anonymous, 2,300 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
