Silverado MyLink Software upgrade / hack to add Text messages?
Nickshu
I wonder if this will be affected when the 3g to 4g upgrade is rolled out in a few months. I know there will be an upgrade, not sure what it will encompass. I am going to hold off for now. Looks great though!
  • Replies 40
How are videos played and which formats are supported?
Thanks
The unit supports MP4 and DivX formats for video.
I'm testing the best bit-rates for quality and file size right now. Setting up a profile in my video converter once I find the best balance over the next few days.
What is the 3g to 4g upgrade???
The upgrade is for the 2015.5i trucks nothing to do with trucks already on the road. The unit also plays a ton of Mpeg formats, AVI etc. The SMS integration also works on iPhone and Windows phone but you cannot reply to messages on iPhone as of right now.
The screen unit doesn't have HD resolution so it would be hard to get it to play HD videos.
  • 4 months later...
The unlock features include
Blu-ray/DVD Video In-Motion (Vehicle must be equipped with RSE. This system will not add Blu-ray or DVD)
USB and SD Card Video In-Motion
Adds addition Video Formats Including DIVIX
Adds SMS Texting App (System will now display or read your incoming text back to you while you keep your hands on the wheel. Certain Android phones will allow you to replay back. Phone dependent)
Optional Welcome Sounds (These happen when the vehicle has been sitting dormant for a period of time. When the driver door is opened and the animated logo comes onto the screen. Volume levels can be adjusted in the menu or turned off completely)
If I added the factory nav option that Kodiakz put out will this make me lose nav again since I have to send the HMI in? Does anyone know?
So if I have the non-Nav option, would this add Navigation to?
Our unlock will not add NAV. It simply unlocks the in-motion restrictions. You would need to purchase NAV upgrade to add the factory navigation
You will NOT loose NAV…we simply unlock the in-motion restrictions. Nothing else is affected.
What all is offered for non navigation units??
So for Non-Nav units…you gain video in motion from the SD/USB slots in the center console. We add 2 other formats that do not come from the factory. So you will be able to use MP4, DIVIX and AVI for video formats. System seems to like the DIVIX the best for some reason. You will also gain the SMS icon on vehicles built prior to 2015 ½ and for the 2015 ½ vehicles you will actually be able to view the message in motion instead of just hearing them over the audio.
What is the turn around time right now?
Now do we have to send you something or can you send the software over the computer and we can just plug and play ? I'm only looking for the video in motion I have a 2015.5 so I have the texting app already ..... I just want video in motion
We have come up with a new program that makes this a little easier to get this done. You can send the module in to be programmed if you'd like...however your vehicle will basically be out of commission while the work is being done. If you would like to send it in we can do the service for $299.00 plus shipping back to you, which cost would depend on where you live and how quick you want it. Turnaround time once we receive the module would be a min. of 24 hrs to get it back out the door to you…it will not go back out the same day we receive the package.
Option 2 is a lot more popular; we can send you out a preprogrammed module to swap out for $349.00 plus shipping. This is normally $399.00 but we discounted it for forum members. We will be sending you out an $800.00 piece of equipment so there will be a core form that will need to be filled out and sent back to have on file. There will be no additional charge upfront, but the form is just to guarantee that we get your old locked module back to use in new condition.
Either option you go with the unlock will give you NAV Entry In-Motion (as long as your vehicle is equipped with factory navigation), Video In-Motion from your DVD/Blue Ray (If equipped with the factory overhead entertainment system), along with USB/SD MP4 & DIVIX In Motion as well as allowing for the viewing of the text messages in motion and not just having to listen to them which doesn’t always come out right.
Two questions ..... how well is your software ? And how does it work? Do you plug a computer into the module and just add the video in motion ? Or do you guy completely rewrite the software. Second question ... is if I'm driving threw town would someone be able to stop by and have the video in motion added ? Possibly for a cheaper price ?
    • $3.90 to $4.50 depending on the brand and location of the station. 87 regular.
    • Guys that read Dizzy's thread know that eons ago after multiple manifold pulls to clear the CCV orifice I converted it to a PCV system with an orifice below it via the valve cover. The blow-by (sticky rings) was so bad it was impossible to keep clean and accumulated water in the oil in the winter when the moisture would freeze in the fresh air side. The PCV functioning mainly as a check valve. I carefully sized the orifice to reproduce the factory values for crankcase pressure at idle.    Well...took a slug of oil to get my attention but the ring seal improvement meant the system was over drafting sucking oil up and out the breather. (V8 guys with orifice systems are nodding their heads). So today I choked it down...allot....to replicate the "just enough to hold a piece of paper on the fresh air side at idle". May still be to much but I'm working with shims at the moment. When I get it sorted I'll make a proper plate and plug. Perhaps using carburetor jets to tune it.    So I guess this means it isn't my imagination.    Dizzy is a pig guys so don't go expecting huge moves in equipment (your equipment) that is in much better shape. A needle valve....lord that just came to me....
    • I had a new engine installed with under 5,000 miles. It shut off coming around a residential street corner and wouldn't restart. Dealer indicated it seized. New one has been fine since with 10,000 miles on the replaced engine. Annoying but I was given a loaner for the 5 weeks it was down. I won't go with the 6.2l gasser so it's 3.0l again. I love the economy and it tows my enclosed car trailer just fine.
    • Coming back from towing a car to my daughter in Nashville truck started making a screaming noise from underneath.  Pulled over placed in park and sure enough whining noise from underneath.  Dropped at the dealer fearing new tranny or another front pump/cover replacement.  Service writer said it sounded like the tranny too...  Well $300, new idler and a belt all is good.  Pop the hood and give a listen. lol  Now I'm telling dealers I'm no longer interested in a new truck.
    • HD uses the 6.6 gas.   Oil consumption while heavy working is considered normal.  1 quart per 100 gallons of fuel is the normal rate above 8600lbs GVWR.  If more than that, it is considered excessive.   They will have to perform an oil consumption test using the guidelines in TSB 03-06-01-023J.     Information on Engine Oil Consumption Guidelines All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons, and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the combustion process, part of this oil layer is consumed. As a result, varying rates of oil consumption are accepted as normal in all engines. Oil Consumption Oil usage has a direct relationship with the amount of fuel used. The harder an engine works, the more fuel and oil it will use. Therefore, oil usage as a factor of fuel usage is a more accurate indicator of acceptable oil consumption levels than vehicle mileage for vehicles at or above 8600 GVW. The accepted rate of oil consumption for gasoline engines in vehicles at or above 8600 GVW is 1 liter (1 qt) within 400 liters (100 gallons) of fuel used. This rate only applies to vehicles under warranty, maintained in accordance with the appropriate maintenance schedule, driven at legal speeds and within design intent of the vehicle. Many factors can affect an owner's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption. Gasket and External Leaks Inspect the oil pans, engine covers, and the engine oil cooler for leakage. Inspect for oil leakage into the engine coolant. Improper Reading of the Oil Level Indicator (Dipstick) The vehicle must be parked on a level surface to obtain accurate oil level readings. Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked. Not Waiting Long Enough After Running Engine to Check Oil Level The vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading to assure the oil has had enough time to drain back into the crankcase. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked. Improper Oil Fill After an Oil Change Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner's Manual or Service Manual for information on recommended oil quantity, viscosity, and quality. High Speed or High RPM Driving Continuous driving at high speeds/high RPMs may increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected. Towing or Heavy Usage Towing a trailer or hauling additional weight will increase oil consumption. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption. PTO Operation Operation of a PTO will increase fuel and oil usage, as the PTO driven accessory uses engine power to operate. Crankcase Ventilation System Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use. Oil Dilution from Condensation On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture, may give the customer the impression of excessive oil consumption. Engine Temperature If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order. Engine Wear Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption. Measurement of Oil Consumption Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).   Verify that the engine has no external leaks. Repair as necessary. Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual). Park the vehicle on a level surface. Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that most of the oil has had time to drain back into the crankcase. Check the oil level and record the vehicle mileage, date, and exact oil level on the form included in this bulletin. Next ensure the oil level is at, but not above, the full mark on the dipstick. add oil if necessary. Also ensure the proper viscosity and quality oil are being used as recommended in the Owner Manual Ask the customer once they have consumed 100 gallons of fuel schedule an appointment and return to the dealer for inspection. If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, explain to the customer that their engine meets the guidelines for oil consumption.
