ditch IFS in favor of Dana 60 solid axle?
I know there are companies that offer this but has anybody on here done this personally? Im looking at selling my 2004 F350 and buying a new 1ton...... i looked at the new F350 and from a Ford guy im not into the circus looking front ends. Looked at the new GMC trucks and there are SO nice! Only problem i will not buy a IFS truck, i hunt fish off road etc and im not going to be buying IFS parts ever year to keep it together this is the reason for the solid axle swap. Ive never seen one of these in person but they are all over the internet and i have passed some on the highway before, just wanting personal expirence with this setup?
  • Replies 37
The new ones are beefy and even older ones like mine are fine. If you plan on staying stock size tires you'll have less problems than you would with a new ford. The new fords ball joints are junk.
I have a less beefy front end cuz it's an LMM, I have bigger tie rods, pitman/idler arm supports (about $500 for that stuff, cheaper than a ford front end) and I've never had an issue. It still has factory ball joints at about 220,000kms. That's countless boost launches on 35" tires, all kinds of bush, fishing/hunting mileage. In the mountains too...
I would deff not be worried about the IFS, last of your worries IMO.
SAS will run you about 8 grand to do it properly...when you can spend $500 and get the same results.
No way you'll be buying parts every year...if you really were that hard on stuff than you would be buying parts for anything you bought...
on my 04 F350 i installed a four inch lift after the first year with 35" mud terrains, do alot of towing (small backhoe) 10k dump trailer for work and mild offroading, hunting, dirtbiking that takes me way off paved roads to get there and i have 126,xxx miles on my truck all with original ball joints unit bearings in the front end. So the comment on how Ford's ball joints suck didnt happen to me. My perfect truck new GMC 3500 crew cab long bed SRW with cummings motor, allison trans, Ford leaf spring axles and Ford manual tcase....
Urs is 04 high steer, they are good. I'm talkin 08+
Was urs a 6 litre too?
My old 98 was only a 1/2 ton, but as hard as I was on the truck the IFS stayed pretty wrong. The most I've had done to the front end steering and suspension wise was ball joints and a pitman arm. This was all in the 10 years that I owned it and it was 6 years old when I got it. Hell to prove how hard I was on that truck, I had the rear diff spider gears go out twice so I replaced the whole axle and had the engine blow up twice. The 1st time the oil pump went out when I was mudding and I didn't know it had went out. The 2nd time it just seized up while hauling ass on a dirt road. That's when I decided to sell the truck to the shop I usually go to and bought my current truck. HD IFS is stronger also so you shouldn't have any problems.
IFS is fine unless you do an 8" or bigger lift.
^^^or you throw HP at it and launch it under boost in 4x4...even then $500 is all you need to spend. And it will be as tough as any SFA, I can attest to that.
I have seen both Dodge and Ford front ends throw a tie rod off (Both D80)... haven't seen it happen on a GM personally.
In my opinion the GM independent front end is as good/better than any stock solid axle. They have been doing it this way for over 20 years..... Tie rods are pretty well protected and the arms are beefy. Also no low front diff or full width tie rod to smash.
Additionally, the GM's have a better frame by far, it's much more rigid than the competitors'. Remember that the framework of the SuperDuty's hasn't changed much in the last 10 years. VS the GM which was really beefed up in '11. Google "GM flex test".
If you really want a solid axle, keep the pickup you have... Low miles and you don't have to pay for it again, lol. And why go with a 60? Do the f350's not come with an 80 now??
Nope been Dana 60 for years and years, steering has changed. Same with some of the suspension geometry, but it's been a Dana 60 for years. I think some models had a Dana 50 too!
Ford has almost always had 35 spline Dana 60's for years, they went from a king pin to ball joints sometime early 90's...
I've looked into this as well, if I wasn't paying for an engine right now I would be doing this...
4 link set up, coil overs, ford Dana super 60 (out of 08+ f-450), convert from 10 lug to 8 lug using 05 f-350wheel bearings and use rotors from 04 f-450. And because it's 08 you can still retain TPMS, like I would anyways. But you could. That set up would cost you about $4000 just for the axle alone, then it's another $3-4000 for the rest of the set up (if you do the welding and labour yourself)
You can do the swap just as good with AAM 9.25" axle as well, but this you get beefier u-joints, better steering ankles and sharper turn radius...even better than just the regular Dana 60. If it gonna shell out the cash, the super 60 is best!
But...in reality you don't need to go through all of that. GM's front end is just fine for the average guy. And if it's not, $500 and worry free!
Yeah all the power that's been through yours and it's still ok should say something...
I guess I was thinking the F350 had a D80 because that's what our Dodge 3500 has. I was pretty sure our old Ford did too but I guess that shows how much attention I pay to fords!
Dodge ran closed knuckle D70s into the early 70s, then opted for a conventional D60 (open knuckle) with drive slugs (not drive flanges) or external lockouts. They used that until the late 80s. They then changed to internal hubs around 90. All versions of the Dodge D60 until 1993 were kingpin and most were 35-spline 1.5" inner shafts and 30-spline outers. The later 90-93 D60s were the best front axle Dodge ever used...
In 1994 they used the unitized hub asssembly, center-axle-disconnects (CAD), and ball joints...they lost the CAD in the early 2000s. These were driver's side drop. These axles suffered death wobble with worn components. They have small diameter axles and stub shafts...
In 2003, they swapped to the 9.25" AAM with ball joints and unitized hubs...the center is very similar to that used in the GM 2500/3500. The early versions had issues with the steering linkage (inverted Y) and changed to an inverted T. They had issues with loose ball joints because they lack any preload ability. In 2008, they updated the steering assembly, but its still the weak point. These also suffered death wobble with worn components, but it was worse because of the ball joint design. They also have small diameter axles and stub shafts, but no CAD.
Personally, I would run the IFS and see how it holds up...then I would worry about an SAS if it was a worthwhile investment. I'm not sure I see any less components on the solid D60 than the IFS that will be prone to less wear...you still have tie rods, you have king pins versus ball joints, and you have spring bushings versus A-arm bushings. King pins are noteably stronger, but they really don't like mud/water...and less so than the modern ball joint. Both use a similar tie rod end...
And its CUMMINS, not CUMMINGS... :)
no V10, 4.30 gears, detroit locker and i ordered it with six speed manual and manual 4wd. And 6.0 are absolute garbage
-im not getting into that frame argument on here........ i will say when big rigs go square tube then ill think about it, not till
-Ford and Dodge use D60 front axle there is no such thing as a front D80. Dodge and Ford use the D80 rear axle in their duallys
    • Did you ever find a resolution to this? my 2019 Silverado 1500 is showing the exact same headlights issues with the exact same symptoms.  would help a ton if anyone has any advice on this or better yet a known solution..
    • Wawa and Meijer here have ethanol free (88 & 89) I use for my mower and lawn equipment.  Its not much more than reg.  I paid $3.29 a few weeks ago.
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • NewDude, thank you for the suggestions!    I did follow up and the dealer indicates he has an open CX case and is working with DPAC (Dealer Parts Assistance Center).   Per the dealer, GM has had a quality spill and is not providing an update for when a replacement engine will be available.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
