going to 20 inch tires
What do I need to do to switch from 17" stock rims to 20" stock rims? The new 20 " ones have the sensors included as do the 17".
I have a 2007 NBS Silverado and the 20 " rims came off a 2012 Silverado.
Much thanks.
Jack up the truck. Remove the lug nuts. Remove the 17's. Put on the 20's and lug nuts. Tighten the lug nuts. Lower jack.
there are 3 different stock rim sizes for these trucks (4 if you include the 22s) all of them are ~31" in diameter.
You can swap between any of the rim sizes with the OE tire size without any major difference in your speedometer. (you may have ~.5mph difference on some but its not a big deal.)
I've been wondering if there's any weight difference between the rims.
Check out 1010tires.com. You can compare the rim/tire sizes and it will tell you speedometer readings , tire height etc.
Only thing the guys have left off.. you need to program your tpms on the new rims to match your truck. Otherwise, its as simple as putting them on.
It's on my to do list too.
It looks like the 1010 calculations are indicating I would be going 2.86 mph slower than my speedo. Isnt there a thing on that for the ecm to correct?
Many of the available hand held tuners have the ability to adjust the speedometer for a change in gearing and tire size.
275/55/20 are the same diameter as 255/75/17 or 265/70/17. Your speedo will be dead on essentially. But you will need to program the new sensors to your pickup.
This. As I said. You don't need to make any corrections.
Right.. I have the 17s with the 255s as well. I did the calc on 1010 and it was something very small in the speed discrepancy.
I'd ultimatley like to go with 20s. They're a bit pricey right now tho. Especially if you want OEM.
Ok I went to the online used areas in my region and bought a set of stock 20 inch alloy rims with GM caps and TPMS. $ 850.00. Absolutely mint shape. The tires on them were bald.
Took truck to Fountain Tire and purchased Wrangler Duratrac 275 55 R20 tires $ 310 each. I get a 60 dollar mail in rebate so I will be doing that.
I took the managers Avalanche and drove it like a rental to work and got there and called him asking about the TPM sensors and he asked me how old the existing ones were . I told him I had no idea and he said they are good for about 5 to 7 years so he sold me 4 @ $ 49.00 a piece. They copied the programming from each of the existing 17 inch tire TPM's and pasted to new ones marking the tire locations on the new sensors.
Installed tires and loaded all the old stuff in back of truck. I was back at the shop during lunch and still managed to get a few burnouts in with the Avalanche before its return. I told the Manager I liked his truck and it had a lot of power !!
Much better look and I am happy with the service
Just a point to add here. the new tires are way quieter than the previous Duratrac's I took off. Not sure how to explain that but a noticeable difference in handling and smother ride.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
