Adjusting door hinges - risky?
Retired Bob
My dealer has been trying to reduce the wind noise from my drivers side door. He has taped the door-to-frame seam and driven the truck - the noise is eliminated. He has adjusted the door striker and even installed a new door weather strip. While there may be some wind reduction, the noise has not been reduced in the 60mph range to the quiet level we both hear (do not hear) in driving other 2014 double cab LTs. He is now suggesting sending the truck to the off-site collusion center that does their body work to have the door hinges adjusted ,but, he said that is always risky of maybe making the noise worse as the hinges are put on at the factory with a robot to exacting and specific specs.
Is the slight improvement already done in wind noise reduction preferable to having a shop mess with the hinges? The wind noise is not excessive but still hearable by me (and the dealer) and it is sightly irritating to me at about 55mph and higher.
Bob not to sound like a smart ass rather than have someone mess with your hinges, I'd turn up the radio see if it covers it up. I'm not sure what it's for but the fender to body gaps of my Denali have this stuff that looks like carpet padding don't know if it's for sound deadening or not. The hinges are welded to the door jambs, can you imagine the mess that could result, plus the fix isn't guaranteed. IMO
Why not glue a second layer of weatherstripping to the factory weatherstripping. Don't even need to use the whole piece, just maybe cut the additional stripping in half (the long way, length wise) and then glue one of the halves to the factory stripping. Just a thought.
Why not have the service manager have the GM rep or one of the factory technician's come out first and look it over before going that route. it could be something that cant be repaired to factory specs, in that case it would lie on GM to replace the truck or set the repair procedure in place.
I adjusted both of my driver side doors the day brought it home. It is whisper quiet now and only took 20 minutes
When you say you adjusted both doors do you mean the strikers? If so could you explain how this is done. Thank you
As SouthernSilveradoGuy85 suggests, maybe some weatherstripping - Lowe's and THD offer several choices of weatherstripping that look like they could be used. Here is a link to a company that appears to make sponge rubber weatherstripping for vehicle doors:
http://www.mdteam.com/index.php/products/weatherstrip/rolled-packaged-door-a-window-weatherstrip
Frost King also has a highly rated (by users) foam that adheres well.
BTW, my 2014 truck has the door hinges bolted on (not welded). Still, it looks as tho the bolts probably go into non-adjustable holes. That probably means the collusion shop would need to weld the existing holes and drill and tap new holes - probably not something I want done.
Think I will experiment with the foam tape to see what happens - at least I will now if the wind noise is 'fixable'.
I loosened the top hinge fairly loose, the bottom hinge I just barely loosened(bolts holding hinge to cowl). I pushed the top hinge forward enough to line everything up. I did have to raise the striker slighty. Both of my driver side doors were sitting unlevel, i.e. the chrome strip and body lines did not line up at all..
Now everything is perfect. 10 minutes finding the wrench that would fit in such a tight area, 10 minutes adjusting.
I did a 'dollar bill' test today - held a dollar bill against the weather stripping along the top of the drives side door and shut the door and then pulled the dollar bill out and observed the tightness of the bill to remove it. I did this test in multiple spots.
The dollar bill pulls out of the driver's side door with noticeably less resistance compared to the passenger side door which is harder to pull the dollar bill out.
The drivers side door (along the top) appears and feels to stick out from the top of the cab more than does the passenger side which seems to be more recessed compared with the top of the cab. Nothing drastic, but still noticeable.
On earlier dealer visits to solve the wind noise on the drivers side, per the Invoice - “Adjusted front and rear doors for better fit plus striker adjustment. Weatherstrip poor fit – ordered weatherstrip replacement - replaced weatherstripping”.
Still have the wind noise n the driver's side so, I will provide this dollar bill test result info to the dealer tech next week.
  • 3 weeks later...
The dealer ordered new door hinge bolts that are designed to allow some 'adjustment' to the door. Both the service manager and I agree the new bolts did not really help much so the next step is to send the truck to the body/collision shop where they have experts in body/frame/door/etc adjustments and let them make adjustments to the door so that it makes a tighter contact with the door frame. The drive's door does not contact the door frame as tightly as the passenger door does. I can stand in the bed and sight along the door to frame gap and it is so obvious that he driver side door needs adjustment. Hope this is the 'fix'.
  • 2 months later...
Was anyone able to get this resolved, either by dealer or body shop, by having them adjust the doors/striker bolt? Any tips? Picked my truck up from the dealer yesterday after they supposedly fixed the wind noise (and performed some other routine maintenance), needless to say I still have wind noise at around 70 MPH. Very irritating. Service document says "Adjust left and right front doors."
'14 Sierra CCSB
I would make them keep trying until it's fixed, if they can't fix it they need to resolve it by offering you a truck without the defect. Don't do any makeshift repairs out of your pocket!
Went back to the dealer this morning, now they feel the whistle is caused by the On-star antenna. Which they had to special order, and the saga continues...
  • 4 years later...
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,290 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
