I have a 1999 chevy silverado 1500 with a long bed that needs replaced. Will a long bed from a 2004 silverado 1500 bolt right in and will the tail lights work with the wiring harness?
^ haha soo very true. I'll be interested to see if it can swap over. I wouldn't bet all my money on it, that's quite a year gap. It'll be good to know though for the future.
Bed it identical. Your old harnesss and lights will go right in.
1999 was a split year. OBS vs. NBS.
Otherwise, if your on the correct "NBS" path, it will interchange. GMC's had a slightly different t/lamp socket than the Chevy's too. With a minor mod (via a razor blade) the t/lamps will ALL interchange!! :cool:
Edited by Bad Bowtie2
03+ tail lights plug right into 99-02 beds...
I also bet that its a direct swap.
Need the 03+ tail light harness or mod the 99-02 plugs
  • 4 years later...
The 04 bed geometry is identical. The taillights interchange but have their own harness that plugs in under the bed in the center rear. I have 07 s in my 99. If you don't have the newer harness you need to notch the twist lock hole to use the older harness. I did that. 1 less bulb than the newer but insignificant small bulb
  • 4 months later...
Definitely not identical.  Body lines are noticeably different, would also expect the frame mounting points and the overall width and length to be at least a little different as well,
As for close enough to make work, that depends entirely on your fabbing skills and what you will find acceptable.
  • 3 months later...
  • 4 months later...
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
    • There's a bunch of tea leaves that you've read, but in any case the delayed timing is unusual. Not sure how that relates to the rich at idle vs. 'normal' while driving.   If you're in this deep, might be worth investigating, and re-learning the sensor. What have you got to lose? Plus, it properly fixes the timing cover leak.
