Anyone get the 5 month XM for $20?
  • Replies 35
I find the connectivity to Pandora to be an excellent alternative to XM. Just slap you phone in the holder and go!
Agreed. Not a bad alternative.
My wife is doing Pandora in her Flex. I bought XM for a year for the $84 deal.
Knock on wood...haven't been charged in months. Was supposed to be 6 months for $29 a whilllle ago. Haven't been contacted again, xm still works, no charges on any of my cards
DO NOT call them. Maybe they accidentally put your XM ID in demo mode, which is what all dealer cars have, which is basically unlimited subscription.
Ride that gravy train as long as you can.
Agreed. Or maybe the previous owner bought a subscription, and his new one won't start until the previous one runs out.
The XM sound quality is poor compared to free streaming radio services on my phone...that helped make my decision to not renew.
anyone tried to pay with a gift card? i thought that worked...
i bought a $25 visa gift card at the grocery store - they won't take it because my billing address doesn't match. the visa card does say debit on it so i had them try that and it still rejected...
Ha yeah definitely not calling. And I don't think it was a previous owner subscription because I had it run out a time before and was without it until a promotion.
As for the sound quality vs. phone streaming apps, I don't think the quality is bad, and my phone apps don't work when I'm in the boonies, and they burn up my data.
I just got 6 months all access for $25.00 I told them to send me the bill and I will send a check. No way in hell am I giving them my credit card number..Service kicked in immediately upon verbal agreement.
Just renewed half-hour ago. The most difficult part was understanding what was being said by customer relations person. worked thru that and got another six months for $23.19 including taxes. The XM on my other car expires in 30 days and they were willing to sell me a $119.00 per year packet for each vehicle. after I said, "HUH, WHAT, DUH, and NO, we went with the $20 for six months. They won't extend the $20 for 6 months to $40.for a year but you can call back at the end of the 6 month period and renew. Go figure.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
