I discovered today that my cruise control will not turn on or function at all. The cruise control light does not illuminate on the dash when I push the on/off button on the steering wheel. I've reviewed the fuse diagrams in the manual twice and do not see a fuse for the cruise, so I'm stumped. Anyone know if there is a cruise control fuse, or have any other suggestions?
I remember the bad brake light switch issue on the GMT900s, but didn't that cause the brake lights to be stuck on continuously? My brake lights go on & off normally.
Not on my '07 Sierra. Only issue was the CC. Brake lights were fine.
I'm not saying this is a problem for the K2XX...and it could be anything else.
so long
j-ten-ner
so long
j-ten-ner
Good to know, I'll check that out. Thanks j-ten-ner
I seem to have "fixed" the problem, but now I'm thinking there wasn't actually a problem besides owner stupidity. Yesterday I could not get the cruise to turn on, but I think I may have been pushing the cruise cancel button (with the X) instead of the cruise on button. In my defense, I was tired and driving in heavy traffic. The wierd part was that the cruise symbol did not appear at all on the dash. Now that I've had it on again the cruise symbol is back and remains white when not active and green when on, even after shutting the truck off it still appears in white. I'm puzzled how or why the cruise symbol completely went away, and now I can't make it go away if I try. The only thing I can think of is I had my battery disconnected while installing the HIDs a couple days ago. Anyway, seems back to normal now.
On my older GM cars it was always the cruise control actuator in the engine compartment that failed. But these were mid 80's cars and the actuator typically failed after several years. And the combination turn signal, wipers/cruise control switch used to fail regularly too.
Edited by pm26
The cruise on/off is the button in the 3 o'clock position. If you want to turn your cruise off, push it. This button turns the cruise symbol in thhe dash off/on.
The button in thhe 9 o'clock position only stops the current cruise command, like your brake pedal does. It does not cancel the preset speed, or turn off the cruise feature. You can resume preset speed by pushing the "+" in the 12 o'clock position after stopping previous command with the button in the 9 o'clock position.
Aldo there is no cruise control fuse, the cruise function is handled more than likely via the ECM/TCM/BCM modules.
  • 5 years later...
I had the same problem this morning. Trusty old work truck and the cruise control would not work. found this link and read through it hadn't thought about it being tied into the brake controller but it makes sense. I lightly tapped the brakes a couple times and then tried the cruise control again and it worked. Hopefully it keeps working. thanks!
Edited by Gforce129
Misspelled word
  • 1 year later...
 I've replaced both brake switches cruise control switch on stirring wheel and fuses good no other issues but cruise control not working
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
