Hi all. First post. I bought my 2014 1500 3 days ago. Went out to drive it the next morning and the tpms was not working. The page on the dash that shows tire pressure showed no reading in any of the tires. I checked them and they were all between 34.5 and 36psi. I,ve driven it about 150 miles and no change. I have searched through this forum and havent found anything reguarding this condition. Anyone have any thoughts before it goes back to the dealer? Thanks in advance for any help you might have.
You need the dealer or a tire shop to reset the TPMS's Prolly just got out of sync with the trucks computer for whatever reason.
Thanks for the quick reply. Looks like i'll be going back to the dealer.
I've heard disconnecting the battery for s few minutes works in this situation. Otherwise head to a place like discount tire or the dealer. DT usually does stuff like that for free.
Edited by Blackout07
Sorry you're experiencing trouble with the TPMS not working. I recognize that you are seeking advice from fellow forum member before taking it into the dealership, but if you need any additional assistance, we're glad to help. You are welcome to send us a private message here on the site!
Andraya
GM Customer Care
Thanks again for the advice. It looks like I'll be heading to my dealer on friday.
Just a follow up, I went to my dealer today (Concord Chevrolet) and they reset the tpms and all's fine. It took about ten minutes. Cudos for the dealer. Thanks for all the quick responses!
Orgvett,
Great to hear the dealer was able to resolve this quickly for you. Feel free to reach out to us if you have any questions in the future. We're here if you need us!
Sincerely,
Eddie A.
GM Customer Care
Without disconnecting the battery I know you reset them by putting it on the tire pressure page and then hold the select button (middle button with a check sign on the right of the steering wheel) until it resets (you'll hear a beep). You have to do it everytime you rotate the tires and of course when putting new tires on.
Just for future reference.
I'll have to write that down so I so I can reference it in the future. Thanks SSguy85.
Ha I didn't realize til you shortened up the name that it also said SS.
And no problem. I'm pretty sure that's all the dealer did.
Edited by SouthernSilveradoGuy85
  • 5 years later...
I have same issue, no readings. I bought the tool and it wont reset. Maybe batteried are out on them. Honks twice and driver front marker lights on. I point tool and nada. I take air out and nada. No numbers on dash.
Edited by Manny77
  • 4 months later...
Did you ever find a solution for this? I’m having the same issue where no tool is working to reset my sensors. The truck is a year old.
Edited by Jlouie26
  • 4 years later...
I have a 17 silverado, about 182000 on it. My drivers front TPMS quit working than a short time later drivers rear and passenger front, I recently had a rotation done and my passenger rear is still the only one working, I would have thought if the sensor is bad in the wheel that once wheel was moved to the front then it would show and the pass rear would be out. Is there another sensor on the hub assembly or close to the break system that could be out. I don't want to spend the money on new TPMS if that's not the issue.
    250.3k
    user087
    user087
  • Who's Online   1 Member, 0 Anonymous, 798 Guests (See full list)
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
