Morimoto Sierra Spec HID
Well I had a shop attempt to put this kit in yesterday and they didn't have any luck. he had them installed and they would work for about 30 or 45 seconds then get really dim. he got a lot of flickering as well. so finally after 2 hours of working on it he finally just gave up and took them out. which was fine with me if they're not working properly. pretty bummed about this. i guess i'll be sending these back and looking into other options...btw i believe the guy knew what he was doing. he just built a truck and took it to SEMA and has had experience with these lights before...
  • Replies 233
I installed this last weekend. They have worked perfectly from the get go. No flickering what so ever...
just sounds like hit or miss with this system... im chatting with TRS right now to find a solution. i really want these to work but im not going to have my headlights go out going down the road...
really sounds like these are hit or miss. im chatting with TRS right now to find a solution. i really want these to work but im not going to have my lights go out driving down the road...
I am an engineer and this is my third HID kit from TRS. I do not believe these kits are hit and miss. I truly believe it is the installers, but defective parts such as the ballasts, happens sometimes.
any idea what would cause dimming or flickering?
It's a voltage issue, but it could be a lot of different things. There could be lose connection, not hooked up correctly, the relay or the ballasts might not be properly grounded, the capacitor could be defective, the relay could be defective, the ballasts could be defective, ect. The best way to try to diagnose the issue is to start at the bulbs and work your way back. Make sure everything is like it should be. You could try hooking one ballast up at a time and see what happens and so on.
okay, thanks for your help. im going to try a different shop with the instructions from TRS that they gave me. hoping this works... will update.
do you have the CAN-Bus code eliminators??
Nope. Just two bulbs, two ballasts, 1 HD relay, and a capacitor.
Gotcha, thanks. found a shop that was able to take a look at them today. so fingers crossed they get them going!
No problem! And that's awesome! Keep us posted! :)
Well no luck on the second shop installing them. They said they tried every possible way to connect them and they would still flicker... looks like im sending these back to TRS
I hate to hear that. But the people at TRS are great to deal with and they will help you on getting this fixed.
the second shop even tried different ballasts, relays and capacitors. The lights still just flickered... im disappointed and have submitted a return and refund to TRS
