Morimoto Sierra Spec HID
I ordered this kit on Monday, received it today and can't wait to install it!
pics and details on installation please! i've got this kit coming in monday! could use some tips for installation! Thanks
  • Replies 233
Installed yesterday. Cutoff isn't perfect, but install was easy and much better than the halogens
Did you try rotating the bulbs? The cut off should stay perfect in the projector housings if the bulbs are installed properly.
Kit on its way. 5000k. Did not order separate can-bus. Does anyone know if this is necessary for install?
Cant wait to see some pics of these lights on a wall 25 feet away
Or any pics at all
please post pictures. I was about to order some HID's in the next week or so. Did you have to modify the bulb at all like everyone else did buying a different bulb or since this kit is specifically for our trucks it fits perfect. what color ballast did you get? 5k or 6k?
I bought DDM HID's almost right after I bought my truck and they were working fine once I installed the canubus and relay but then the relay connections got moisture in them and the metal rusted after a hard freeze here in Houston. So I ripped everything out and now im trying to find something of a little better quality.
The bulbs only go in one way. Three tabs, two big, one small.
No, the kit comes complete
Wraxx
The bulbs can get cockeyed the way the projector socket is made. One or two tabs can be out of socket instead of under the lip. This makes for a bad beam.
Gotcha. Well, my lights look great and tested fine last night. However, on the way to work this morning my left light started to flicker, like, strobe light fast. I hope its just a loose connection because I know my grounds are solid. I'll be reseating the plugs when I get home tonight to see if it corrects the issue. Next step would be to swap the ballasts I guess.
Ok thanks. Have you had any issues with flickering, buzzing or bulb out codes? I'm guessing you have the kit on your Denali.
    Enduro73
    Enduro73
  • Who's Online   2 Members, 0 Anonymous, 1,648 Guests (See full list)
