Morimoto Sierra Spec HID
  • Replies 233
Is that the 4300 kit?
It's the 5000k. That picture was taken with my crappy iPhone camera. But it's pure white. The fogs are also 5000k.
I installed the 5five (50 watt) 5k sierra spec kit, works great and is very bright, only problem I had was the relay buzz, turns out I had the wires flipped from the oem harness to the relays, flipped them and all is well. Be sure to make good grounds, I used sand paper to sand to bare metal. I love mine
Do you have an SLT Sierra? If so, does that 5five watt kit at 5000K match your LED DRLs In color? I'm getting my projectors retrofitted soon and I am looking to get the 5five kit and need to know what will match.
Did anyone snap pics of their install? I am looking for ideas as to where to mount the balasts. Was thinking right on the side of the headlight toward the radiator using HD velcro. thanks
5k 35w TRS kit. Very happy with the ease of install. Clean packaging. I would post pictures but i cant share from google + and the files are too large to upload :(
My relays buzzed like crazy after install but only when the truck was running. I simply unclipped my capacitor and flipped it over and plugged it back in. Problem solved. No flickering issues, love the lights.
im curious why you need the harness?
the original reason HID kits needed the harnesses was to make them run full 12v off the battery when the vehicles DRL were designed to only have a output of 6v for the main beam headlight then switch to 12v for low beams, and have a stand alone high beam bulb.
since our bulbs run 12 v all the time (i assume) there is no need in theory for a harness.
ive always ran vvme.com kits and never had a issue
Yes I have an slt sierra. The 5k does not match perfect but plenty close enough for me. Most are saying the led are more 4500 range. I looked at them the other night. If I looked from the side I could barely tell the difference. If I got in the light stream I could not see the leds because the hids were so bright. Long story short. Not enough color difference for me to worry about and I love the 5 five 5k hids
I had best buy install mine yesterday I must say there better but no where near great. My chevy trailblazer was amazing with hids. Now I'll find some real headlights.
Our trucks do not run 12 volts all the time. The headlights run as a DRL during the day.
honestly didnt notice mine running as DRL during the day.
is it only when they are in drive?
