Removing center caps?
I need to recheck the lug nuts on my wheels since i just brought new tires.  How do i remove the center caps?  I only had my truck for 3 or 4 months now and i'm learning alot about it on here.  I love this place!
Thanks,
:nono:
On the stock aluminum wheels, twist the black plastic lug pieces in the center cap like you would remove regular lug nuts (same wrench size as lug nuts).  With all 6 undone, the cap will come right off. :thumb:
I remember the first time i tried to take em off.  I had a screw driver and a hammr  :flag:  :nono:  :)
When you go t put them back on, look at the inside of the cap and the rim.  There is a small tab on the cap that lines up with a slot on the rim so it will fit right.  I know some who have lost center caps beause the didn't line those up and it didn't quite fit like it was suppse to.  :thumb:
I own a truck...it's not for work...
it doesn't tow a lot...it doesn't haul a lot in the bed...
but it's mine to use as I see fit.
Tom, I see an official GM-Trucks creed there. :nono:  :thumb:
