Did your High Country come with skid plates? Never have really got a good answer from GM...the option sheet says "Underbody Shield (Transfer Case)"
Edited by Langer19
No metal skid plate from what I remember. I can give you a definite answer tomorrow. There's just a plastic "skid plate" up front that you gotta pull to access the front diff
Sent while in 'Murica...
Yeah that would be cool if you could let me know. If you wanted a metal one you have to buy it aftermarket?
Yeah probably but for the front you don't really need it to metal. It's just to keep stuff from kicking up into the engine bay
Nope, no skid plate here [emoji34]
Looks to be the same bolt pattern as the skid plate I took off my 02. May touch it up with some paint and stick it under there just because this truck is so much lower
Had these sitting outside when I got home
Took 5 min. to install. Passenger side you had to add retainers so that was the "difficult" part. All in all just need to give them some time to lay flat and they'll be much nicer! Here's some finished shots
What to do next... hmmm....
Ammm new rims.
Give me a few years to get around to needing tires and you're first in line to get these wheels [emoji106]
Years. Lol. Ok your not leveling that beauty any time soon... I'll have some summer rims by April. I understand tho. Driver assist handle, under rear seat storage thing. And your done
I actually have a level kit on my parts shelf but gotta send it back cause they sent the wrong one. I was just gonna run stock wheels and tires until they were gone. Not worth me buying new wheels and tires yet
Huskys. Those WTs do not fit.
Just gotta give them some time to settle in. In my 02 they fit great
Also saw this the other day. I'll have the dealer take care of it when I go in for my stabilitrak light always being on
Oh no! That sucks. Just from the pics I've seen and the feedback I've read I wouldn't buy WTs. Do they all hang over the door plates like that?
Yeah they all do that. I'm not too worried about it. I've had nothing but great luck with weathertechs in my other truck. I'll tell my buddy to order some huskys for his ram 1500 so I can compare
I've never owned a set but hear the quality is excellent. Just been hearing a lot about the fit on TYF vs the huskys.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
