Question about Max Trailer (NHT) option
Awesome...can you take a picture of your payload sticker? Also what tires were included? Thanks!
I'm showing my ignorance here, but where can I find the payload sticker for my truck? I see the tire presure sticker on the inside of the driver door...is that it?
  • Replies 44
The other sticker is on the bottom of the B pillar.
Look down....way down....I couldn't find it at first either!
But I think it just has GVWR and GAWR's, rather than a payload number. Payload figure would depend on where in the vehicle the weight was added.
The fleet site has option weights only. I presume it's all the fluids but fuel. In your situation you're probably right on the weight front. For our family we have one more person than seats in the truck so we take two vehicles everywhere. 26*6.3 ~ 164lbs plus 430 lbs of self-loading baggage plus about 200lbs of bikes, coolers etc. All of our stuff that fits is loaded in the RV but with the massive tw it still puts us over our gvwr but under the gcvwr
Curb weight is the total weight of the truck with full tank of fuel, no cargo, no passengers or driver.
It actually provides payload capacity specific to the options on the vehicle without deletes. (see: http://news.pickuptrucks.com/2014/08/gm-commits-to-standard-payload-calculations.html) Subtracting payload from GVWR will give you actual vehicle weight with full tank of fuel but no driver. In my case the available payload is 1499lbs (just below the seating capacity). If you use the order guide weight calculator you get the same solution.
You are absolutely right...you and I were posting at same time. Guess I've been fudging my numbers on the conservative side.
I'd be curious to know how this compares to other Sierra 1/2 tons!? (1,843 pounds)
What tires did they include on your truck? Under your seating capacity on that sticker what is the payload? Thanks for your help!
Sorry for delay --- so running boards were swapped to the powder coated black ones (factory), bug deflector the lund one ( realized today installed over hood not around it... and the rims are off my 2010 SLT (factory rims) 18" I am running Nokian Haklleppta R2's on it for winter. I wanted to get the 20's like redwngr has posted but couldn't find a decent priced set, and the tyres would have been an additional $500.
Canopy on back-order to 2nd week of January.
  • 2 years later...
Hi, guys,
Great information, but I've a different sort of question. I have a 2016 Silverado LT, with the Z82 trailering package. If I wanted to upgrade to the NHT, what would I need in the way of parts?
I have the 5.3L/6 spd automatic, z85 suspension package.
Thanks
Hi, guys,
Thanks
all 4 spring sets
new rear axle
4 shocks
Factory brake controller (not possible)
Tow mirrors
A very worthwhile package, but not really worth trying to add later
From the 2016 order guide:
NHT Max Trailering Package, includes 9.76" rear axle, 8-speed transmission with 3.42 or 6-speed transmission with 3.73, (JL1) trailer brake controller, enhanced cooling radiator, revised shock tuning for increased control, heavier duty rear springs and increased RGAWR
On SLE - Requires a Crew Cab or Double Cab model. Includes (G80) heavy-duty automatic locking rear differential on 2WD models (already standard on 4WD models) and Z82 Trailering Package. Requires (L83) 5.3L EcoTec3 V8 engine and (DPN) power camper mirrors. Not available with (GAT) All Terrain Package and (Z71) Off-Road Suspension Package. Includes (UHN) 18" X 8.5" bright-machined aluminum wheels. Requires (RBX/RBW) 18" tires or may upgrade to (RD3) 20" ultra bright machined aluminum wheels with either (RC7) or (QSS) 20" tires.
On SLT - Requires (RBX/RBW) 18" tires or may upgrade to (RD5) 20" chrome wheels with either (RC7) or (QSS) 20" tires. With (L86) 6.2L engine, requires 20" wheels with (QSS) 20" tires. Requires (DQS) power adjustable, power folding camper mirrors. Not available with (GAT) All Terrain Package and (Z71) Off-Road Suspension Package.
Thanks for all the great information guys. Now on to my next question, what's all the buzz about airbag kits? if a truck is rated for 9200lbs, like mine, would throwing a airbag kit and gears get me to that elusive 10,400lbs rating? I don't need to get there, I'm just wondering how else I can achieve the NHT package rating for towing if Chevy won't put the option on, after my truck is built. I'm just crunching ideas, so this is merely an exercise for me on understanding the draw/appeal for those goodies I can buy in the aftermarket that have all these great capacity ratings?
Could I put 3.73 gears in my Z85 axles? or am I throwing money away? would it raise my towing capacity?
Sorry, there is a couple of questions in there.
Thanks
Thanks
You can't ever change your rating with any amount of add on parts. You may fine and well make your truck safer and more capable, but the sticker is the sticker and doesn't change. If you want your truck to be legal with a heavier weight... trade for a better equipped truck... bolting stuff on won't change a sticker rating
    HWN808
    HWN808
  • Who's Online   3 Members, 1 Anonymous, 945 Guests (See full list)
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
