new member
chuckstruck2
I just purchased a 2015 silverado Z71, took delivery December 15 2014. It's been in the shop 6 times 2 for EVCM computer and had to be replaced. 2 times for a vibration when it goes to V4 and driving in town 30-50 Mph almost feels like the shift points or wrong and tranny is in too high of a gear for the RPMS. 2 times stuck in 4wd and
W/N come out and has service 4wd and service stabilitrak notification. GM better do something about this i have less than 1600 miles on vehicle. Has anyone experienced any of this? PLEASE HELP. HAVE REPORTED ALL TO GM WANT THEM TO SEND ME A NEW IDENTICLE TRUCK ASAP.
I'm sorry to hear about your luck, I also have a 2015 silverado but no problems so far *knocking on wood. Hope they get you a new truck ASAP!
Thank you for the welcome, I will keep everyone posted on the outcome. I think i have driven a loaner more than my new truck. I am sorry I traded my 2007, I never had any problems all I changed was tires and brakes on it. :(
Very sorry to hear about all the problems, maybe you can get some advise from other members. Welcome to the group Chuck.
Well update on my truck, it is still in the shop at the dealership and 3 ot of 5 days this week. I spoke with a GM adviser today and they offered me for compensation was a 24 month personal protection plan for my truck. Well if they would have looked at my account theywould have seen that my truck already has that on it. I stress to that advisor that I no longer wanted to speak with them and to elevate my issues to the highest that they could elevated to that can authorize a buyback of my truck and give me a new one. My dealership Edwards Chevrolet in Iron Mountain Michigan has been awesome and has accommodated me in every way they can. I have contacted my state representative and advise them of the issue and told them also of what I want to keep me a satisfied Chevy customer and my truck will be sitting on the lot at Edwards Chevrolet until my new truck arrives. I don't know how far this will go but I am NOT happy with my new truck and they better make this right in some way. Please advise if anyone else is experiencing A prominent shutter when the engine drops off four cylinders and also the transmission shift points seem to be wrong when in the v4 mode. Also if anyone is having a problem with their 2015 Chevy Silverado getting stuck in 4 wheel drive and will not respond to the switch which means the vehicle is stuck in 4 wheel drive and will not come out.
Check your state laws. My state is three times to fix a problem before you can file for lemon law. If GM helps out before great, but best to plan for needing to follow your states laws incase it comes to that.
Welcome to the forum Chuck! I too hope GM makes this right for you. best thing is to be persistent. Good luck.
This is why I'm here, to hear people's experiences, good and bad.Thankyou for your input and hope it resolved to your satifaction.
Sorry to hear of the issues. Here is what a quick search yielded on MI Lemon Laws:
A defective vehicle is one in which the same problem has not been repaired after four attempts, or a vehicle that is out of service 30 days or more for repairs.
http://www.michigan.gov/sos/0,4670,7-127-1585_1611-23885--,00.html
Hopefully it doesn't come to this, but sounds like you are close to the limits.
