Is the a speed limiter on the duramax?
I was on the freeway following my wife in her Mini Cooper S, when she took off so we started playing. At close to 100, my truck felt like it laid down.
Then I started checking the dic thinking maybe there was a speed limiter but couldn't find one. Can anybody confirm if they do have a factory speed limiter? My speedo goes to 140 if that helps;)
You can't adjust the governor in the DIC, the only thing in the DIC that's similar is where the truck can warn you when you reach a certain speed. It's probably governed at 98 like my '14 and my 98 Z71 that I had. Some K2s are governed at a little over 100 but there's no common denominator. Some say it's tire ratings, but not really agreeing with that unless I see actual proof from GM that that's the reason.
Yeah, it seemed to shut down at 98. Can the dealer raise it or is it something that can only be done w a tuner?
Tuner
No need to even ask the dealer because they will just ask why are you going that fast in a heavy full size truck. I see no need to go that fast, but I can't tell anybody what to do lol.
Did i forget to mention the disclaimer that it was done in a closed course with professional drivers?
Only way is with a tuner. Speedo range doesn't matter and realistically it only goes to 140 to accommodate use in Canada where they use the metric system. Especially on a HD truck I'd be wary about exceeding the speed rating of the tire.
Leave it alone, I have seen the YouTube videos of driveshafts exploding at high speeds.
I love to drive fast and do stupid stuff but 100mph is plenty for a tall 7,000lbs truck with E range tires and stock driveshafts.
His truck can definitely use that 140 speedo! Just gotta get a good tune [emoji4]
Hardly. Driving a truck that fast without proper tires and driveshaft mods is stupid.
Yeah with the factory driveshaft nobody on here would recommend that. Really need to have high speed tires for going 140. very dangerous
  • 4 years later...
No tuner will over write the programming on the truck, however if the speed limit is let’s say 75 and three cars are going 70 in front of you
you may have to accelerate to above 90 to
pass all three, by the way you can’t go 100 mph in a L5P it falls on its face just above 94
I have a Hypertech Max Energy tuner that allows me to program in the limiter... Currently have it set to 130.  Would I drive that fast?  Hell no.  But it is nice being able to hammer on it and pass a long line of cars on a 2 lane highway and do it quickly.  I've had it to 115 and didn't take it any faster.  Never will.  Unless being chased by a bunch of pissed off women!
    Greg3160
    Greg3160
  • Who's Online   3 Members, 0 Anonymous, 372 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
