Max tire size with rough country front leveling kit
etton
Hey guys I have a 2014 black gmc sierra all terrain crew cab in which just installed a rough country front leveling kit. Just want to know what the tallest and widest tire I can install without any rubbing? I have the stock 20 inch rims on. Thanks!
I'm running the Toyo OC ATii eXtreme 295/55/R20s on OE 20x9-27 on a 2" front only RC leveling lift with no issues.
Ok i was thinking of going with the 295 60 20 in that exact brand..but not sure if it will rub since the tire is 33.9 diameter..How do you like the toyo extremes?
perfect. that's my take on the 295/55/R20. great footprint, sets well with the 27mm offset OEM wheels, relatively quiet.
That's awesome I cant wait to get mine...think i'm gonna try the 295 60 20 and hope they will fit with if any or minimal trimming of the liner!
Let us know if they fit!
Your 295/60/20 AT 2's are $350/ tire.
295/55/20 AT 2's are $338 per tire.
275/65/20 AT 2's are $275
295/55/20 toyo mts are $370/ tire
Just seems really expensive for an all terrain tire.
To each their own, but I would go with the 275/65/20's if it were me.
275/65/20 Toyo Open Country M/T. Toyo specs (34.5x11).
  • 10 months later...
Just got the same tires with Pro-Comp 2.25" level and they are rubbing the sway bars.
    needafix
    needafix
  • Who's Online   5 Members, 0 Anonymous, 591 Guests (See full list)
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
